Question about Panasonic Microwave Ovens
The door on our Panasonic "The Genius" Inverter won't close. The hooks on the door seem to have free play and won't grab when the door closes
  • Panasonic Master
  • 9,098 Answers
There is a spring inside the door that holds the latch (hooks) down.
The spring is connected by a little tab or loop on the back of this latch assembly and one on the inside of the inner door panel.
Usually the tab on the inner door panel is where the break occurs.
Disassembling the door and replacing the door panel is a big job.
If you or someone you know is a handyman, you can disassemble it and epoxy in a piece of material to replace the broken mounting tab / loop.
It must be squeaky clean and dry and you need to let the epoxy set up undisturbed for about 24 hours.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
  • wrench77 Jan 27, 2011
    If you have the same microwave (The genius) that I do, I didn't remove the door at all. Open the door and pry the plastic "trim" piece (it's rectangular shaped) out. You will have to locate the spring that has come loose somewhere in the door. Once you've located the spring, all I did was use a zip tie to connect the spring from the plastic latch to one of the metal tabs that surround the inside of the door. Forget the epoxy, the little plastic piece of plastic that breaks off would be nearly impossible to get glued back on there correctly. Hope this helps.
I have to slam the door 5 times to get it to turn on
Have you tried leaving it after GENTLY closing the door once? Many have a timer so that the fan can remove condensation from the inside. If that doesn't work, you need to take it to the nearest Panasonic service centre to have the door microswitch adjusted or replaced. There are no self serviceable options with microwave ovens due to the disastrous damage operating one without the outer case can cause. The use special screws only the tech carry.
At least you have a good make, so worth having it fixed. I used Panasonic ovens in a restaurant setting.
Sep 19, 2015 | Panasonic Genius Prestige Inverter...
My panasonic genius prestige inverter microwave has started to click off after I enter the power & time. Sometimes it will work fine. Sometimes it takes 2 or 3 times of entering then cleaing the i
Check the door latch switch inside the oven. The 4 switches where the door hooks latch on to when the door is closed has to engage with the door hooks to tell the oven that the door is closed. loosen the 2 phillip screws that holds the switch assembly and slide it to adj. and ensure that the switches close when the door is closed.
Sometimes the switches go bad and cannot make contact and must be replaced. If you see that the connectors on the switch is discolored or overheated replace the switch, it is bad.
Jan 15, 2015 | Panasonic Genius Prestige Inverter...
Panasonic genius inverter 1250w door stuck
Sounds like a spring let go, or the plastic piece that the spring hooks onto broke. Either way, the top cover will have to come off. Could be an easy fix unless something broke.
Jan 25, 2014 | Microwave Ovens
I have a panasonic microwave genius protege type AP104A which will not always work after closing the door
Closing the door operates a switch or switches which function as an interlock to prevent the oven from starting unless the door is closed completely. The switch or switches may be defective or misadjusted. Also, the door may not be closing properly to close the switch(es).
Dec 07, 2013 | Panasonic Microwave Ovens
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Apr 28, 2013 | Microwave Ovens
1200 watt panasonic genius shuts down
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 26, 2010 | Panasonic Microwave Ovens
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic inverter genius sensor 1250w, turns on for about 3 sec. then goes off, no codes.
try locating the primary door sensor. this is probably burned. replace the door sensor with appropriate amp rating - usually 16A (or higher) 123vac
Feb 09, 2010 | Panasonic Microwave Ovens
Microwave Ovens Logo
120 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
