Question about AEG Dishwashers
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
  • 11,896 Answers
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Posted on Sep 29, 2010
I have a AEG 50870 Favorit dishwasher, it is not letting water in, although when I manually put water in, it drains properly
Hello.
Had same problem on my AEG F55204 dishwasher.
Problem solved very easily. cleaned pressure chamber only.
see attached pictures
clened aeg pressure chamber-gpfsjtvpk02j51hgnqm10fvj-4-2.pngHope it will help to you as well.
FYG no need to dismantle everything. just take off fwrd cover to check chamber and then use some small wire to clean it from inside.
Oct 09, 2017 | AEG Dishwashers
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
Cycle taking much longer than normal
The most likely cause is the interal water heater is not working or if using hot water direclty in the inlet then the water temperature is below rerecommended level.
Aug 30, 2012 | AEG 24 in. Favorit 50730W Free-standing...
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
AEG Dishwasher 54850 not heating up the water is no getting hot
This could be the electrical element (some use the old traditional element and some (later models) use inductive heater coupled in line with the hose feeding the top sprayer arm. A test with an Ohm meter should indicate if the element is open circuit.
Aug 02, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwasher
This "Inductive heating element"is in line with the pipe feeding the top spray arm. it is about 15cm long and has a clamp at each end with one electrical push on connecter. It can be reached by taking off the back bottom plate and just follow the spayarm down to this device.
Jun 05, 2008 | AEG 24 in. Favorit 40660i Built-in...
Dishwashers Logo
790 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
