Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
My computer is not recognizing the flash drive. It was working fine 5 minutes ago and I didn't do anything to it. tamela.a.vickery@boeing.com
    Brigadier General:
  • 10,406 Answers
Try connecting it to a different computer.
If it still does not work, then it has "died".
If it does work, quickly copy all the files, just in case that you have an "intermittent" problem that could evolve into a "permanent" problem.
Posted on Sep 29, 2010
I just purchased this flash drive, a green case, and when I plug it in my computer will not recognize it.
did you try to plug it in other computer..some of the computers needs some of the drivers so that if you try to plug a device on it..and recognize that you have the driver in your computer otherwise if the driver of your flash drive didn't recognize of your computer..try to search it to your computer if it has on your computer..if not try to search the driver and install it in your computer.
Sep 15, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Forgot my login password how can i login or restore it to factory setting i forgot my password to login
Hi
You need to use the Windows operating CD installer CD and either repair the OS or restore the factory setting using the installer. It will surely remove the password
Mar 08, 2011 | Compaq Presario 700 470024-192 Notebook
Computer will no longer recognize microSD
Go to Device manager and totally remove/un-install ALL/ anything USB...
Then reboot the PC, DO NOT plug anything USB in yet.
PC will start then install usb structure.. then reboot.
NOW try ya USB things ... ya prob good to go.
Jan 18, 2010 | PNY 2GB microSD Memory Card
One of two USB drives wont recognize anything
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Dec 13, 2009 | Toshiba Satellite A205-S5804 PC Notebook
I have a Western Digital Passport that works fine
Western Digital Passports work perfectly on USB ports 2.0 that supplies 5v of electricity with a max of 500mA. If your computer was manufactured more than 5 years ago, it may be using the USB 1.1 which is slower than the current.
Jun 14, 2009 | IBM ThinkPad R32 2658 Notebook
Problems with my mother!
PUT YOUR OLD COMP BACK THE WAY IT WAS .IF IT BOOTS AS ALWAYS,GO TO CONTROL PANEL.SELECT "SYSTEM",SELECT DEVICE MGR,SELECT DISK DRIVES.RIGHT CLICK ON YOUR SLAVE,SELECT UNINSTALL,FOLLOW INSTRUCTS.TURN OFF COMP AND REMOVE YOUR SLAVE.REBOOT.HOPE IT WORKS FOR YOU!
BUME
Mar 07, 2009 | Intel D865GLC Motherboard
Computer doesn't recognize my Lacie HD
From your description it sounds like you power adapter did indeed fail at first, but if the HDD spins now the adapter seems to be working fine at the moment. If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Dec 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
After reformatting my fujitsu lifebook n5010 it doesnt read it.
Is the card reader built into the computer?
I know there are a few card readers out there having trouble reading 2 gig memory cards if the computer or card reader was built over 5 years ago.
If you have a data cable for your phone and software for the phone, your computer should be able to read it that way.
Nov 12, 2008 | PNY 2GB microSD Memory Card
Usb not recognized when I put scan disk in port
do 1 thing plug it on a other PC or on a mac and see what happens !!
then format the volume..
hope this helped...!!
Feb 28, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
Doesn't reocognize songs and Ipod
Try booting it into disk mode. Do this by clicking on the menu and center buttons at the same time. When you see the apple logo, immediatley hold the centerbutton and play button down at the same time for 10 seconds. The ipod should now say disk mode at the bottom and have a check mark on the screen.
Then connect it to your computer, and format it using your computer. To do that click on my computer, then right click on the drive letter assigned to your ipod (should be like drive I: or H: or similar.. Then scroll down to format and click on format. This should reformat the ipod completely.
Once that is done disconnect your ipod from the computer and reset it again using the center and menu buttons. After it reboots, try reconnecting it to you r computer and see if it is fixed.
Aug 21, 2007 | Apple iPod MA446LL/A MP3 Player
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
65 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
