Question about Canon imageRUNNER 3030 Black and White Copier
How do i take off the by pass settings in turn the copier back to auto
  • 68 Answers
On the LCD screen go to the paper select drawer, the touch "letter" size so that the copier now recognizes the default drawer for 8.5x11.
Hope this helps. :)
Posted on Sep 29, 2010
No Incoming or Out going Faxes Out going faxes
Press Setup Button on front panel of printer
Scroll to Fax Settings ( Or Advanced Fax Settings )
You will find ECM ( Error correction mode )
Turn it OFF
Try to receive Fax, IT should work
Jun 25, 2010 | HP Officejet J5780 All-In-One InkJet...
Ricoh Aficio 1232C rpcs When I try to print the red light appears on the printer saying 'load by pass tray' even though I have selected Auto tray. Normally the machine prints fine.
when you selected auto tray was that in the driver or microsoft settings ? microsoft settings will overide the copier settings driver. look under file then page setup to see what it is set for.
May 20, 2010 | Ricoh Aficio 1232C Color Copier
How do you change the number of rings, so that the fax will pick!
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
We have epson bx300f, changed rooms and now have to sit and press buttons on machine to receive faxes where before they would come through automatically. How do I revert back to that setting?
Had a quick look and found that you may have turned off the auto-answer mode.
The way to set it back up is provided on page 5 of this manual:
ftp://download.epson-europe.com/pub/download/3217/epson321754eu.pdf
  1. Press Mode [Copy/Fax] to select Fax mode
  2. Press the up/down arrows to select "5.Fax Settings" then press OK
  3. Use the up/down arrows to select "5.Communication" then press OK
  4. Use the up/down arrows to select "4.Rings to Answer" then OK
  5. Use the up/down arrows to set the number of rings then (yep, you guessed it!) press OK
  6. Press the button for "Auto Answer/Space" (looks like a phone handset with the work "AUTO" next to it) to turn on Auto Answer Mode.
  7. Press OK (for the 4 millionth time it seems!)
  8. Finally, press "Menu" to return to the first screen in Fax mode.
Hopefully that will resolve your problem :)
Mar 25, 2010 | Epson Stylus Multifunction Printer/...
Any way to by pass the Auto Off on my IR 330E?
might be the problem
set them all to --:-- and see what happens
you can also turn the id off
i think you press *,id,stop,*
Dec 12, 2009 | Canon imageRUNNER 210S Copier
What is the code for installing Sharp copier drum?
Using 1 finger
Press clear
press auto (exposure setting)
press clear
press auto
when it works your display will go blank
enter 24
press start
enter 07
press start agin then turn it off and back on
Apr 24, 2009 | Sharp AL 1631 Copier
Envelope printing
Go to custom setting, paper size setting for by pass tray, use custom measurement,input the size of the envelopes ( in X Y mode ). When you print, go to the properties and change the paper tray select from auto to by pass tray.
Good luck.
Mar 11, 2009 | Sharp MX-2300N Color Copier
Receiving faxed
when the machine goes into energy save mode it will still receive faxes. (energy save is a low power mode the copier is still on and can accept faxes, print jobs and copy jobs)
however if the machine goes to auto shut off it will not.
(auto shut off will after a set amount of time turn the power switch on the copier to the off position and the copier can not be used until it is turned back on.)
you need to turn the copier off, hold down 0 & 8 and turn on then type in 206 press start, key in 20 press set then turn the copier off and back on. this will make sure that auto power off is not enabled.
i hope this helps you.
Jun 01, 2008 | Toshiba e-Studio 350 Copier
Beeping noises
try un plugging it for 30 sec and pluggind it back in and if that dosent work by pass the energy saver with a jumper from j1 to j2
Dec 19, 2007 | Frigidaire FAC052K7 Air Conditioner
Canon imageRUNNER 3030 Black and White Copier Logo
50 people viewed this question
old marine
old marine
