Question about General Electric AEM08FM Air Conditioner
The coils in my brand new GE thru the window air conditioner have rusted and there is a smell....this was previously answered, but I can't locate the answer in my email...please send again. thanks
  • 384 Answers
Dear sir
when you had buy this window aircondioner if it,s getting rust. and if there is any type of smell it,s mean in airconditioner.s drain tray is collecting the water and water is not going out bye it,s drain hose, please make sure water shouldn't collect on your air con,s base . and if your product under warranty then contact to your product,s dealer for get help by your warranty period .
please contact to your product,s dealer they will provide you service for further action .
hope answer the question
thank you
please vote!
Posted on Sep 29, 2010
Why is there a ***** smell?
I worked extensively on GE Zoneline AZ Air Conditioners and Heat Pumps while a Maintenance Superintendent at a Senior Citizen's Apartment Complex. Not knowing what type of smell to which you are referring, I can assure you that other than "burnt electrical" smells, the only smell that could possibly be produced would be that from within the INDOOR SPACE. Perhaps something has made its way into the INDOOR AIR FILTER? Perhaps that INDOOR AIR FILTER needs to be cleaned. To clean the INDOOR AIR FILTER, simply lift both of the filters from the front cover, take to your clean bath tub. Run EXTREMELY HOT WATER from the back of the filter to the front of the filter. Then, fill your bathtub 1/4 way with EXTREMELY HOT WATER. Add 1 cup of Hydrogen Peroxide and 1 cup of Real Lemon Juice. Set both filters in this solution for 30 minutes; then rinse with clear water. Set filters up to dry for at least 2 hours in the sun or an air breeze. Replace filters into the GE Zoneline.
Also, not knowing how OLD your GE Zoneline system is, the COILS may need to be cleaned. To do this, simply turn OFF your GE Zoneline unit and remove the front COVER of the unit. Next, mix in a spray bottle 4 packets of LEMON flavored KOOL-AID (without SUGAR) and water. Shake well. Spray the INDOOR COILS of your GE Zoneline unit with the entire contents of this mixture. Let set for at least 10 minutes. Then turn your GE Zoneline to the COOL position. The citric acid in the lemon kool-aid will be forced through the coils to continue to remove any dirt, dust, debris and effectively CLEAN those coils. This will also provide you a LEMONLY odor within your room. Simple and cheap.
Enjoy your GE Zoneline unit.
Aug 30, 2014 | GE Zoneline AZ55H07D Air Conditioner
Trying to locate relay for very old GE airhandler located in attic at a church with model # of air handler unreadable. relay has 24 volt coil built in and has both AMF and Potter and Brumfield stamps. Only...
I have had to rewire the old GE furnaces to where I can set a new relay right beside where the old one was. I know this is not the easiest thing but if this is the furnace I think it is it may be the only answer
May 10, 2011 | GE AJCQ08ACB Air Conditioner
I have a new GEAEM08FM 8,000 BTU ac in my window. (around 7/2010). There has been a mildew smell in my room, and when i looked inside the air conditioner (from the vent at the top), i can see the pipes...
If it was me I would mix a strong Clorox/water solution and spray everything down leaving the Clorox water in the tray...this will kill and fungi/mold and make it smell good...
heatman101
Sep 27, 2010 | General Electric AEM08FM Air Conditioner
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
My LG LWHD 7000 is not heating.
heater coil located behing the front evaporator coil has burnt out. To access the coil you need to remove the a/c from its sleeve and the coil is located between the evaporator coil and the fan motor. An appliance parts house will have the replacement coil if you do it yourself.
Good Luck on your repair hope this helped
Dave
Jan 07, 2010 | LG Heat cool Window Air Conditioner
Why does my airconditioner leak
If this is a window ac then you need the back of the ac lower than the front, so the water can drain to the back.
Aug 18, 2009 | GE AZ28E15DAB Thru-Wall/Window Air...
Window air conditioner repair
when you smell something like that it only means your unit is leaking.the freon/refrigerant is what you smell.so i suggest compare a brand new one with the labor cost for repairs in your area.
May 18, 2009 | Heating & Cooling
Window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Aug 24, 2008 | GE APN10AA Portable Air Conditioner
Strange smell
Have you cleaned the evap coil? Most often smells come from the evap coil. A bleach type product used for cleaning will solve this problem. Thanks
Aug 09, 2007 | Sovereign ARP-900E Air Conditioner
General Electric AEM08FM Air Conditioner Logo
94 people viewed this question
Top General Electric Heating & Cooling Experts
Bill Long
AJMAL KHAN
Are you a General Electric Heating and Cooling Expert? Answer questions, earn points and help others
