Question about Panasonic PT-F100NTU LCD Projector
PT-LC50E LCD Projector
How to reset lamp timer on a Panasonic PT-LC50E LCD Projector after 2000hours. All keys disabled at present. Unable to bring up menu. Only projects lamp change warning in top left of screen and shuts down after 5 minutes.
  • Moss4 May 25, 2008
    I tried this as soon as the projector is turned on but it won't let me. It locks me out and displays the message. Tried several times.
  • info561 Apr 18, 2009
    what i do for erorr f/l
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
  • 115 Answers
Hi
Go to the menu quickly and go to the option of Lamp usage.
press enter continuously for ten seconds. lamp will reset.
Viren
Posted on May 25, 2008
How to reset the lamp time in Panasonic projector model vex 500
  1. Press the Power button so that a picture is projected onto the screen
  2. Press the Menu button to display the "Main Menu", and then press the F or G button to select "Option"
  3. Press the Enter button to display the "Option" menu, and then press the 5 or 6 button to select "Lamp Runtime"
  4. Press and hold the Enter button for approximately 3 seconds
  5. The "Lamp Runtime" will change to "Time Reset [Power Off]"
  6. Turn off the power and disconnect the power cord
Get A Quote for a Panasonic Projector Lamp or to Replace your Existing Projector Lamp now.
Here are some links that will help you.
Change the Panasonic PT AR100U projector lamp in 3 easy steps DLP Lamp...
How to Reset Panasonic Projector Lamp Timer Projector Lamp Services
May 29, 2016 | Panasonic Office Equipment & Supplies
Reset lamp for Panasonic PT-vx400
There should be a menu that goes across the top listing video, audio, setup, projection....etc. Either under setup or advanced there will be a drop down menu with lamp settings under it. Under that menu will be a reset lamp or something as direct as lamp hours. That is where you can reset the lamp timer.
Feb 05, 2013 | Panasonic PT-VX400 Projector PT-VX400
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
I have the Panasonic pt -l759u multimedia projector the lamp timer has reached zero i need to know how to reset it i currently cant even get to the menu
You cannot reset the lamp timer. This is an indication that your lamp is at the end of it's life and must be replaced. Contact Panasonic for a replacement.
Feb 27, 2011 | Panasonic PT L759U Multimedia Projector
What will I do to reset lamp timer for my Panasonic PT-AX200 model
Read very carefully this is the only solution to reset lamp timer
1. Connect the mains lead to the projector and a mains socket, and switch the MAIN POWER on. 2. Press the POWER button.
3. Press the MENU button to display the menu.
4. Select the OPTION menu and press the ENTER button.
5. Select LAMP RUNTIME.
6. Press and hold the ENTER button for approximately 3 seconds.
7. The confirmation screen will be displayed and select OK.
8. Press the POWER button to turn off for resetting the duration of the LAMP RUNTIME.
9. Next time when you POWER ON the projector the duration of time in LAMP RUNTIME is reset to "0 H".
Jan 06, 2011 | Panasonic PT-AX200 LCD Projector
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
Last night, a message started appearing saying the lamp needed to be replaced on our Panasonic LCD TV. What is this and is it something we have to do? I think it's the Panasonic PT-AX200 LCD Projector, but...
the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
Aug 10, 2009 | Panasonic PT-AX200 LCD Projector
RESET PROJECTOR
Menu -> Option 2 -> Lamp Timer -> hold enter 3 seconds -> power off
Jun 24, 2009 | Panasonic PT-LB50SU 2000 Lumen SVGA...
Panasonic PT-L759U
With the power on and the lamp off, hold the input button down on the projector then press and hold the power button for 5 seconds
Nov 16, 2007 | Panasonic PT-AE900U Multimedia Projector
Panasonic PT-F100NTU LCD Projector Logo
1,064 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
