Question about GE Microwave Ovens
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After the second potatoe the potatoes didn't cook. Since I had already put all the potatoes in the oven I didn't realize that the microwave was not heating. Tonight a subway type sandwich was put in to warm up and although from the sound and the the light came on it looked like it was working nothing warmed up. I have tried using the time cook but this hasn't helped. Is there anything I can do to get this working again? Model # JES1451JW 02; Serial# AR 903167 U
  • Anonymous Mar 30, 2014
    Was cooking baked potatoes and it just stopped now it will not come on at all
  • GE Master
  • 9,098 Answers
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 26, 2008
I just bought a new rice cooker container for my family to cook rice. It saids use one cup of rice with 1 and a half of water and microwave for ten minutes. Then thought I use 3 cup of rice then must...
you do not need to triple the time when tripling the quantities, example: one baked potato = 8 min, 2 = 10 min,3= 12 min ....
sounds like a triple batch is a bit much for your microwave
so you may want to cut it in half
Feb 09, 2015 | Microwave Ovens
While baking a sweet potato, the potato exploded and caught on fire. The microwave no longer works.a fire bro
I haven't heard of such a thing. You must have cooked it until there was no moisture left in the potato. That would also account for the failure of the oven. It would be the same as no load in the oven.
A thermal protect part is your current problem.
Apr 02, 2014 | GE SpaceMaker Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
Sharp R959SLMA auto cook not working
please make this test and fix it. God bless you
  1. Check the power diode This electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitor Responsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetron Responsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal Cutoffs Examine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Dec 16, 2013 | Sharp Microwave Ovens
Microwave won't restart after baking potatoes.
If your microwave is not a convection then the moisture most probably is somehow getting to the controls as potatoes has quite a bit.
Oct 27, 2017 | Emerson MWG9111SL Microwave Oven With...
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
It is time to replace the microwave oven, it is 11 years old and prices in microwaves has dropped considerably. To repair the old! magnetron would need to be replaced, "most expensive part" and other unknown problems would need to be addressed.
Apr 24, 2012 | GE Microwave Ovens
Shuts down on potato button only
Not much info to go on here. Are you putting in the number of potatoes vs.the cook time? Most microwave potato functions would not read "5 minutes." It would be read as a request to cook 500 hundred potatoes.
Oct 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
BAked Potato caught on fire in GE Microwave
Fuse is behind the control panel. Has cavity sensors and a magnatron thermal disc also. Start with the fuse and then pull it down if not the problem. Eric
Aug 27, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Microwave Ovens Logo
197 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
