Question about Asko W6021 Front Load Washer
My Asko W6021 washer doesn't run. The power light glows when the power button is on. When I press the start button the machine "clicks" twice after a few seconds but does not start. I replaced the fuses with the ones from the dryer and still get the same result. Also have cleaned out the pin trap. Any ideas?
  • todd_mcallis Sep 29, 2010
    Thanks for your quick response. Nothing happens at all other than the 2 clicks when I press start. No water comes in - nothing.
  • Asko Master
  • 17,130 Answers
The question being incomplete I think you mean the motor is not turning , so check the output to the motor after the water flows in, if there is no action of the inlet water coming in , filling and voltage to motor, then the program controller is faulty. If voltage comes to motor but does not run then it canbe the motor , check the capacitor if this of the capacitor running.
Posted on Sep 29, 2010
  • Officiate Aug 31, 2011
    Having the same issue. Will call local shop for service. What was your winning solution?
My Asko W6021 won't start and the door won't open when buttons are pressed, although the power appears to be on (the red light comes on after power button has been pressed)..
Open the drain hatch at the bottom left of the machine. Open drain pump and check to make sure tat there are no foreign objects in drain pump. Object in the drain pump will prevent the unit from operating properly. If there is water still in the unit, you can use the drain hose to drain the washing machine. If you would like to open the door manually, disconnect power, remove screws holding red plastic handle in place. pull handle.
Mar 15, 2011 | Asko W6021 Front Load Washer
I have an asko w6021 washing machine that won't run. All it does is when the power on button is pushed, and nothing else, it makes a humming sound almost like it's in the middle of the wash cycle. Also you...
Open the hatch at the bottom left of the unit. If there is water still is machine, remove the drain hose and drain machine. Open the drain pump and check for foreign objects, make sure that the rotor spins freely and that there is nothing holding it. This will prevent the machine from working properly
Mar 13, 2011 | Asko W6021 Front Load Washer
WASHING MACHINE WILL NOT START
check motor it may need cleaned and oiled, or it might be bad.
Apr 04, 2010 | Asko W6021 Front Load Washer
Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Mar 28, 2010 | Asko W6021 Front Load Washer
change the carbons theres nothing wrong with the board
Jul 30, 2008 | Asko W6021 Front Load Washer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko w6021 washer not working
replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Mar 23, 2008 | Asko W6021 Front Load Washer
Please help me..
Maybe the 5hr. button is pressed? If so, the machine will wait 5 hours before it starts:)
Feb 09, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Nov 01, 2007 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
503 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
