Question about Altec Lansing Multimedia Computer Speakers
Altec small speakers
Altec lansing acs44: need small speakers and wiring for sub woofer. please advise where i can obtain these speakers.
    Problem Solver:
  • 41 Answers
Doesn't look like they make that anymore.
Posted on May 25, 2008
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on...
Throw it away, they are garbage speakers. I ordered one and ended up giving it away as it was so dire. It hissed when turned off, it drove me mad! The part you are missing is the amplifier which is in a small box unit in the right hand front speaker. Power goes into it and the input audio is amplified and goes to the Sub Woofer and the two satellite front speakers.
It will work on a stereo amplifier, but not as it is.
Manual
Using the Speaker System Altec Lansing ADA885 User Guide
Set up
Setup Altec Lansing ADA885 User Guide
Mar 10, 2018 | Altec Lansing Audio Players & Recorders
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
My altec lansing mx5021 speakers problem
The problem I have found is the contact glue between the back panel and circuit board inside the sub woofer. The glue becomes conductive after some time (2 years..!!) and needs to be scraped away from across tracks, you can tell the problem areas as the glue is pale yellow but goes brown and conductive over time. Good luck.
Regards
aj
Feb 18, 2010 | Altec Lansing MX5021 Computer Speakers
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
201 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
