Question about Bosch Washing Machines
Hi David here.My washing machine carries out the cycle till it gets to rinse and goes no further.Tried putting it onto spin and drian but it tries to carry on but stops.,
  • Bosch Master
  • 17,130 Answers
You will need to see the voltages to the sections , the spin, the drain and then confirm if the voltage stops from the program controller or the motor by itself.
If program controller stops action , check all inputs, check thedoor switch, check the connections, check the board.
If not the error canbe the board itself.
Posted on Sep 29, 2010
The machine starts going thru the wash Cycle and then it goes past the rinse cycle and then it shows OL after the spin cycle.. It even does this when you have no cloths in it. I went to rinse and spin...
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer is getting stuck at rinse cycle-
sorry to keep asking questions but i just need to know a little more information. are you using auto fill? have you tried manual water level settings? is your machine the one with the LCD DISPLAY?when it stops at rinse, is it agitating? if you have the LCD display have you tried the- traditional wash mode? please reply 4 further help.
May 21, 2010 | Fisher and Paykel GWL11 Top Load Washer
The dial goes through rinse cycle without drianing the water.
Not switching into spin. Could be electronic or mechanical problem. Get the answer with a service call to find out if it is worth repairing.
Oct 20, 2009 | General Electric WBSR3140GWW Top Load...
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Mar 29, 2008 | Washing Machines
HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Sep 24, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Machine stops and goes to end half way through a cycle
Check the filter is not blocked it sounds as if it cannot drain in the time allowd at end of wash cycle. Regards Advisor
Jan 17, 2007 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
