Question about LG Flatron L1718S LCD Monitor
The monitor don't turned on - LG Flatron L1718S LCD Monitor
    Problem Solver:
  • 5 Answers
Ther must be some power problem with yr LCD, YOU NEED TO CHECK POWER CABLE ATTACHED TO YR LCD
Posted on Sep 29, 2010
I turn on my computer and i don't see anything
Guess what? I don't see it either.
Oh,....that's because you're there, and I'm here, and.............never mind.
(OH, I'm jus jokin'!)
Would be helpful to know the laptop manufacturer name, and model number, though. The name you know, the model number is on the bottom of the laptop.
Diagnose to see what the problem is;
A) Graphics chipset,
Or
B) Video Cable,
Or
C) In the Display Assembly
1) Suggest start with attaching a VGA monitor to the laptop.
Laptop OFF, monitor OFF, attach the VGA cable of a VGA monitor, to the VGA connector on the laptop.
Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on. By factory default the display should show on the external VGA monitor.
IF not;
There are at least 3 display options available,
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Hold the Fn key down, and tap once on the Display Toggle-Over key.
Which key is the Display Toggle-Over key?
Don't know. You didn't state the laptop manufacturer name, and model number.
It is one of the F keys at the top. F1 through F12.
Usually has a monitor symbol on it, and a side arrow.
(Most of the time the F4, F5, F7, or F8 key)
No display on the external VGA monitor?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
Still no? Bad graphics chipset.
Display shows on external VGA monitor? Problem is the Video Cable, or in the Display Assembly.
Post back in a Comment after you have performed this procedure, and also post the manufacturer name, and model number.
If the graphics chipset is good, we'll go on with the diagnoses if you wish.
Regards,
joecoolvette
Jul 14, 2012 | Computers & Internet
Lg flatron monitor L1960Tr stopped working. Last week it turned on very slowly . Now It does not turn on at all
Hook up the monitor to a working desktop computer. If you still don't get video or lights to come on then the Monitor is dead and would need to be replaced. You can also try anotherworking monitor on your desktop to make sure its not an issue with the computer.
Oct 02, 2011 | LG L1960TR 19" LCD Monitor
HAS IT GOT SOUND, DO NOT KNOW HOW TO TURN IT ON
Since you don't clarify what exactly your monitor model is, I can't tell you that it has (or not) sound capabilities. Either clarify me the exact model or make this simple test: check at the back of the monitor if a small green hole (connector) 3,5mm diameter exists. If you can locate it your monitor has the audio capabilities and you have to connect this connector with the same green connector at the back panel of the computer case using a cable like this:
In case you don't have a cable like this you can find at any computer or electronic shop, or buy on line for about 2$ to 7$, depending on how long the cable is.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
I
Aug 05, 2011 | LG 19" LCD Monitor
My monitor is turn off when i change rezolution is work only at 800*600 at 1024*768 don't work is turning off idk what to do please contact me
That means your video card and/or your monitor does not support that resolution. Check what the maximum resolution your monitor can handle. You can find that out by asking your monitor's manufacturer or looking up the model of your monitor online. If you're sure that the monitor can handle that resolution but its not working, try updating or reinstalling your video card driver.
Jul 19, 2011 | Samsung SyncMaster 720N Monitor
Can I clean my ViewSonic LCD Monitor (VE510b) with water (using cloth)? Please tell me a procedure how can I clean my ViewSonic LCD Monitor screen.
To clean the monitor first turn it off then use something like a microfiber cloth or something that is not abrasive to clean the surface. Don't press down excessively this can cause damage to the monitor. If that does'nt get all the fingerprints and such off a solution of distilled water with a little
white vinegar will do fine just use it lightly and don't drown the monitor. Make sure to use just enough solution to lightly dampen the monitor and not so much as to run down the monitor and
risk getting inside where the circuits are.
May 20, 2011 | ViewSonic VE510b (Black) 15" LCD Monitor
On my viewsonic moniter it is displayed as OSD LOCK
press in the three buttons on the monitor ( + , - , and menu) at the same time , connect the power cable, that will reset the monitor to the factory settings
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | ViewSonic E70f 17" CRT Monitor
My monitor works fine for weeks than suddenly just goes black! I turn it off and back on and it only stays on for about three seconds than goes black again! The power light stays on!
take off the monitor data cable from pc and try to turn monitor on if appears a smal square on the screen that mean your monitor is ok , and the black screen reason maybe data cable or vga card.
note : your monitor resolution is 1680x1050 some times wrong resolution cause like this problems
best regards
Apr 22, 2011 | Acer P221W LCD Monitor
I can not get my monitor to work with my laptop can you help??? I have the power cord in and the monitor cable and I booted them in the correct order, nothing
Hello!
Are you try in grafik option dual monitor?
If you know go in grafik option, you have one option dual monitor (something like that, depend of grafik card, if intel that is so).Enable that option and turn off laptop. Put monitor cable in laptop and turn on monitor.
I don´t know am I help you, but that must work.
Nov 02, 2009 | Acer AL1916W 19" LCD Monitor
The lcd monitor does not have a picture and will not shut off when it has power.
§ Turn Off the Monitor.
§ Unplug all the Cables from the back of the Monitor.
§ After unplugging all the Cables press and Hold the Power Button at the Front of the Monitor for 20 Seconds.
§ Plug all the cables back.
§ Turn it on.
§ See if you get the Picture on the Monitor.
§ if you don’t get any Picture then.
§ Unplug the Cable which is connected at the Back of the CPU.
§ If you get the Message "No Input Signal” or "Check Video Signal" it means that Your Monitor is Fine.
§ Try doing the Factory Default settings from the menu Buttons at the Front of the Monitor.
§ If you don’t get any Message then it means you Monitor has Gone Bad and Needs to be replaced.
Jul 05, 2008 | Computers & Internet
LG Flatron L1718S LCD Monitor Logo
46 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
