When we send and receive faxes via our Brother Intellifax 4750e, there is a large black line on the right of the page.
    Scholar:
  • 107 Answers
Hello, if this line is larger than 1 inch, and you already checked toner and drum, then the problem will be the actual scanner, this unit will need to be replaced,
Posted on Sep 29, 2010
We have a Brother intellifax 4750e. When we send a fax, there is a black streak down the right hand side of the paper. When we receive a fax, the streak is not there. The streak is about 1" wide. ...
Try cleaning the rollers with rubbing alcohol using a good quality paper towels, I find there is a buildup on the rollers causing streaking on the paper. If that fails the print head must be suspect.
Dec 30, 2010 | Brother Office Equipment & Supplies
I have a brother 4750e fax that is sending occassional barcode looking black areas on the right side of page. receives OK Has new drum and clean scanner glass
My first guess is a bad drum unit. Inside the assembly is a soft, plastic blade that scrapes off the toner that didn't make it onto the paper, so the next page will be clean. If dirt is stuck under the cleaning blade, it may skip, making marks like that on the drum, which get transferred to the page.
Do you still have your old DR-400 drum, or can you borrow one from another machine? Swapping drums is the ideal test, if you can avoid buying a new one. If your new drum is bad, the seller should exchange it.
Jun 23, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother fax 4750e can not receive or send fax. sender said the line just ring and ring endlessly
To set up for receiving Fax, do the following:
Press Mode button repeatedly untin Fax and Fax/Tel lights are lit.
Faxes will automatically print and answering machine will take the calls. If you have a dedicated fax line, do the following:
Press Mode button repeatedly until just the FAX light is lit. Then the machine will answer every call as a fax.
Apr 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
When we copy on our 4750e fax it comes out with black page
Can you see light from the scanner unit with you make a copy or try to send out faxes? The bulb for the scanner may be burnt. You might be able to find a replacement bulb, search google or contact Brother.
Jun 16, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
181 people viewed this question
jasbo
jasbo
