Question about Epson Stylus CX5400 All-In-One InkJet Printer
We have been given a CX5400 Epson printer. One of the cartridges (magenta) was missing. We then ordered compatible ink cartidges from our usual on line supplier - (internet-ink.co.uk). We found that two of the inks (yellow and red) are too small to fit - the black looks the same and the blue (different from the other two) looks similar to the originals still in the machine. My husband wedged the magenta in and it is working but the colours aren't mixing properly but it is usable. I sent the inks back as instructed and it cost me nearly 14euro to do so. However they sent back exactly the same ones. (which as I said my husband has wedged in even though it (the compatable one) is a different size to the original red one. As we are country folk and haven't been able to get to a shop to check can you tell us if I should get on to the suppliers again as I don't understand how they can be right. What should they be like. Three different sizes or what? Would be so grateful for your help - just stumbled upon your site. Many thank Pamela Duncliffe, Cork, Irleland.
    Brigadier General:
  • 10,406 Answers
In Windows, click Start
Click Control Panel
Click Classic View
Click Printers
Be sure that the installed printer is listed as the 'cx5400' printer, not some other printer.
Talk to a different supplier, e.g., http://www.theinkshop.ie
in Ireland.
Posted on Sep 29, 2010
  • timnpam Sep 30, 2010
    The printer is listed properly it is the size of the cartridges that I have a problem with.
  • ikkenom Sep 30, 2010
    Did you get any help from the people "behind" www.TheInkShop.ie ????
Epson rx595, installed compatible ink cartridges some time ago and it worked fine, now the yellow and the light magenta given error (cannot recognise ink cartridges,) put original epson that are empty back...
Swith machine off
clean pins in cartridge holder with (lightly) damped lint free cloth
Now try with compatibles
By the way, never mix originals with compatibles.
Good luck and don't forget to vote for more sharing.. thank you
Nov 22, 2010 | Epson RX595 Photo All-In-One Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My magenta ink is out and the printer is showing error. Is there a way I can still print with my black and white cartridge.
in the epson cx5400 you can not still print pecause the printer sign red light on the ink the printer design stop from the factory for this now you change the all set not only magenta that is better because the printer make clean when you change and that take charge from the set ink I think you understand what I mean thank you
basher66
Dec 01, 2009 | Epson Stylus CX5400 All-In-One InkJet...
The cyan and magenta cartidges have run out but I cannot print in black only, since a staus window appears telling me to replace cartridge the cyan and magenta and will not let me continue to print in...
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Nov 08, 2009 | Epson Stylus Multifunction Inkjet Printer/...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Compatible ink cartridges dx8400
Epson cartridges are microchipped.
Do your new cartridges carry the same chip?
If not, they will not work.
If all else fails, return them to the supplier and explain they are not recognised by your printer.
Feb 18, 2009 | Epson CX8400 All-In-One InkJet Printer
Epson CX5400
take out the cartidge and see if there has been a leak. If there has gently clean away excess ink, then replace cartridge and clean the print heads
Sep 23, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Ink cartidges
Without knowing where your "compatible " cartridges came from, it's difficult to say. The correct cartridge types for a 1290 are T007 and T009. Do your cartridges with lugs show these numbers? In general, compatible cartridges will fit into the cartridge carrier without problem. Yes, Epson did fit plastic key lugs to their cartridges to artificially make cartridge A different to cartridge B, when in reality they were identical e.g. C46 and C48. Now, compatible cartridges for your printer are incredibly cheap on E-Bay. My advice is just to throw away the troublesome luggy ones you have and buy some more on E-Bay - they will fit without trouble.
Feb 08, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson CX5400
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Jan 04, 2008 | Epson Stylus 680 InkJet Color Printer
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
