Question about HP Office Equipment & Supplies
How to replace ink in cartridges - HP Office Equipment & Supplies
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-mechanism.
Wait 10 seconds.
The print-head will slide to some position.
Push down firmly on an ink-cartridge, to "unlock" it from its socket.
Gently lift it out.
Slide-in the new cartridge.
Push "up" on the cartridge to "lock" it in its socket.
Posted on Sep 29, 2010
For the HP printer I have, you pull down the front of the printer; then on the right side you will see the printer cartridges; pull down and out on each one to remove it; then insert your new cartridge by pushing it down and forward. Close the front door. It will conduct an automatic test print and then you are ready. You will have tape to remove from your new cartridge before inserting it however. Hope this helps!
Do I have to replace the color ink cartrigdes in my epson xp-610 printer
Q:
How do I change the ink cartridges?
A:
Do the following:
Removing and Installing Ink Cartridges
Make sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Leave your old cartridges in the printer until you are ready to replace them to prevent the print head nozzles from drying out. Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability.
  1. Make sure that the CD/DVD tray is not inserted for printing.
  2. Turn on your product.
    • If an ink cartridge is expended, you see a message on the LCD screen. Note which cartridges need to be replaced and press OK . Then select Yes, replace now and press OK .
    • If you are replacing a cartridge before you see a message on the LCD screen, press the left or right arrow buttons, select Setup > OK > Maintenance > OK > Ink Cartridge Replacement > OK . Then press the start_black_icon.jpg start button.
  3. Lift up the scanner unit.
    Caution:
    Do not move the print head by hand; otherwise, you may damage your product. Do not touch the flat white cable inside the printer.
  4. Push in the blue tab to unlock the ink cartridge you are replacing. Then lift the bottom of the ink cartridge to remove it.
    Warning: If ink gets on your skin, wash it thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If ink gets into your mouth, spit it out and see a doctor right away. Keep ink cartridges out of the reach of children.
  5. Recap the used ink cartridge using the cap that came with it.
    Note: Dispose of used cartridges carefully. Do not take the used cartridge apart or try to refill it.
  6. If you are replacing the Black (BK) ink cartridge, it is recommended that you shake the new cartridge gently four or five times before unwrapping it. You do not need to shake the Photo Black (PBK) cartridge or any of the other color ink cartridges.
    Caution:
    Do not shake the cartridges after opening the packages, or ink may leak.
  7. Remove the cartridge from the package.
    Caution:
    Do not touch the areas shown above. Doing so may prevent normal operation and printing.
  8. Remove the cap from the cartridge and store it in the bag that came with your product for later use.
    Note: Save the cap so you can recap ink cartridges before storing or disposing of them.
    Caution:
    Do not remove any other labels or seals, or ink will leak.
  9. Insert the ink cartridge head first into the ink cartridge holder. Then press the bottom of the ink cartridge down until it clicks into place.
  10. Once you replace all the cartridges that need replacing, close the scanner unit.
    The product starts priming the ink. This takes a few minutes. When you see a completion message on the LCD screen, ink replacement is complete. Note: If you see an error screen telling you an ink cartridge is installed incorrectly, lift up the scanner unit and press the ink cartridge down until it clicks into place. When you\'re finished, close the scanner unit.
If you remove a low or expended ink cartridge, you cannot re-install and use the cartridge.
Caution:
If you remove an ink cartridge for later use, recap the ink cartridge using the cap that came with it to prevent the ink from drying out and to protect the surrounding area from getting smeared by ink. Store the ink cartridge in the same environment as the product. Do not leave the product with the ink cartridges removed for an extended period of time. Otherwise, ink remaining in the print head nozzles may dry out and you may not be able to print.
http://youtu.be/xJsDu52txEA
Nov 17, 2014 | Epson Expression Premium XP-610...
Colour ink cartridge not reconise. replace colour ink cartridge.cod 3603
To resolve the issue:
  1. Make sure you install the correct type of KODAK Ink Cartridge for your printer. Currently we offer two types of ink cartridges (10 Series and 30 Series). Installing the wrong type of ink cartridge may result in this error. You will need to install a new, correct type of KODAK Ink Cartridge.
    NOTE: For more information, see Which ink cartridges to buy for all-in-one printer.
  2. If you are using the correct type of KODAK Ink Cartridge, reinstall the color ink cartridge.
    1. Open the printer access door.
      NOTE: If the ink cartridges don't move to the center, see Printhead and ink cartridges don't move to center with access door open.
    2. Wait until the printhead is idle and silent, then pinch the latch on the color ink cartridge with your thumb and forefinger and lift it out of the printhead.
    3. Install the color ink cartridge back into the printer, making sure to press down on the thumb tab until it clicks into place.
    4. Close the printer access door. For printers with LCDs, follow the instructions on the LCD screen.
      For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
  3. If the error continues, restart your printer:
    1. Turn off the printer by pressing the power button.
    2. Wait five seconds.
    3. Turn on the printer.
  4. If the error continues, and you have extra, new KODAK Ink Cartridges on-hand, try to install a new ink cartridge (or a set of new ink cartridges).
  5. If the error continues, contact us.
When the issue is resolved, we highly recommend that you upgrade the firmware for your printer for optimum performance:
  1. Locate and select the firmware for your printer.
  2. Follow the instructions to install the firmware.
Source: http://support.en.kodak.co.uk/app/answers/detail/a_id/39315/selected/true
Jun 07, 2011 | Office Equipment & Supplies
How do i change my ink cartridges in my epson workforce 520 series 3 in 1 printer?
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Leave the expended cartridge installed until you have obtained a replacement, or the ink
remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If a cartridge is expended, you must replace it to be able to print or copy. If a
cartridge is low, you can continue printing until a cartridge needs
replacement.
If you're replacing a cartridge before you see a message on the LCD screen,
press xMenu, press u or d to select Maintenance, and press OK. Then
select Ink Cartridge Replacement and press OK.
3. Open the scanner, then open the cartridge cover.
4. Squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used
Warning:
If ink gets on your hands, wash them thoroughly with
immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package,
shake it gently four or five times. Then remove
it from the package.
6. Remove the yellow tape from the bottom of
the ink cartridge.
Caution:
leak. Do not touch the green chip on the front of
the cartridge. This can damage the ink cartridge.
7. Insert the new ink cartridge into the holder
and push it down until it clicks into place.
8. Once you replace all the cartridges that need replacing, close the cartridge
cover and push it down until it clicks into place.
9. Close the scanner.
10. Press OK to begin charging the ink. This takes
about 2 1/2 minutes. When you see a
charging is finished.
Caution:
Never turn off the product while ink is charging or you'll waste ink. If you see an ink
replacement message on the LCD screen, press OK and press down all the cartridges
securely. Then press OK again. If you remove a low or expended ink cartridge, you
cannot reinstall and use the cartridge.
See Page 47 in manual
Download Manual Here
May 23, 2011 | Office Equipment & Supplies
How to replace catridges for Epson Stylus Office T40W??
Good day. I hope this steps can help you in replacing your cartridges. This how i remember doing it. Just follow these steps.
>Make sure the power light is on, but not flashing.
>Open the printer cover and the output tray.
>Press the ink button. The ink cartridge holder moves to the ink cartridge check position and the
power light begins to flash.
>Press the ink button again. If more than one ink cartridge is expended or low, the ink cartridge holder moves to the mark.This
occurs each time you press the ink button until all expended or low ink cartridges have been
indicated. Once all of the expended or low ink cartridges have been indicated, the ink cartridge
holder
moves to the ink cartridge replacement position when you press the ink button. >Open the cartridge cover and place the ink cartridge into the cartridge holder with the bottom down.
Then push down the ink cartridge until it clicks into place. Then close the cartridge cover
>Press the ink button and then the printer moves the ink cartridge holder and begins charging the
ink delivery system
Hope this will help you a bit with your ink cartridge replacement problem. Have a great day.
May 22, 2011 | Epson Computers & Internet
I have replaced black ink cartridge 73N message on screen says Error i press ok to proceed message goes back saying replace ink cartridge?
The main problem in using the latest Epson printers, is the ink replacements. Ink cartridges like 73N has its own ink reseter (the little chip in front of the cartridge). Once you replaced the ink without using the right procedures, for example you have a 10% remaining ink level on one of the cartridge, and you replaced it without using the setup menu and selecting the replace ink cartridge, even though the cartridge is new, the printer will read the replaced cartridge as a 10% ink level cartridge. When the remaining 10%, drops to 0%, your cartridge will read as an empty cartridge. The chip on the cartridge is registered as an empty cartridge.
-try to replace the ink reseter or try to clean the cartridge chip then put back the ink.
Mar 23, 2011 | Epson Stylus TX400 Series
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I don't know how to change the ink cartridge of epson tx 110
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
SEE IMAGE BELOW
Warning:
Keep ink cartridges out of the reach of children and do not drink the ink.
Note:
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Mar 21, 2010 | Epson Office Equipment & Supplies
I have a Brother MFC5460CN...I can't find the owners manual and I can't figure out where the ink cartridges are? I need to replace them
I found this on the Web site. You can download the manual for yourself. Just click on the link below. If you find this information helpful, pls rate me.
http://www.retrevo.com/d/ds/progress?doc=9adbcf37695f2981dab6cde6d0fdb2d1
Replacing the ink cartridges B
Your machine is equipped with an ink dot counter. The ink dot counter automatically
monitors the level of ink in each of the 4 cartridges. When the machine detects an ink cartridge is running out of ink, the machine will tell you with a message on the LCD. The LCD will tell you which ink cartridge is low or needs replacing. Be sure to follow the LCD prompts to replace the ink cartridges in the correct order.
Even though the machine tells you that an ink cartridge is empty, there will be a small amount of ink left in the ink cartridge. It is necessary to keep some ink in the ink cartridge to prevent air from drying out and damaging the print head assembly.
a Open the ink cartridge cover. If one or more ink cartridges are empty,
for example Black, the LCD shows Ink Empty Black and Replace Ink.
b Pull the lock release lever down and take out the ink cartridge for the color
shown on the LCD.
C Open the new ink cartridge bag for the color shown on the LCD, and then take
out the ink cartridge.
d Remove the protective yellow cap (1). Each color has its own correct position.
Insert the ink cartridge in the direction of the arrow on the label.
f Lift each lock release lever and push it until it clicks, and then close the ink
cartridge cover.
G If you replaced an ink cartridge, the LCD
may ask you to verify that it was a brand
new one. (For example, Did You Change Blck?) For each
new cartridge you installed, press 1 (Yes) to automatically reset the ink dot
counter for that color. If the ink cartridge you installed is not a brand new one, be
sure to press 2 (No). If you wait until the LCD shows
Note
If the LCD shows No Cartridge after
you install the ink cartridges, check that
the ink cartridges are installed properly.
Pls rate met. Thanks and Good Luck.....
Feb 05, 2010 | Brother MFC-5460CN InkJet Printer
How to load the new ink cartridge. HP Photosmart C5140.
Replace the ink cartridges (from the manual for the printer)
Follow these instructions when you need to replace ink cartridges.
To replace the ink cartridges
1. Make sure the HP All-in-One is turned on.
2. Open the ink cartridge door by lifting from the front center of the device, until the door locks into place.
3. Squeeze the tab below an ink cartridge to release the latch inside the HP All-in-One, and then lift the latch. If you are replacing the black ink cartridge, lift the latch on the far left.
If you are replacing one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
4. Pull the ink cartridge toward you out of its slot to remove it.
5. Remove the new ink cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Make sure that you insert the ink cartridge into the slot that has the same shaped icon and color as the one you are installing.
6. Press down on the gray latch until it clicks into place.
7. Repeat steps 2 through 5 for each ink cartridge you are replacing.
8. Close the ink cartridge door.
Jul 04, 2008 | HP Office Equipment & Supplies
54 people viewed this question
Seeker5211
Seeker5211
