Question about Baumatic AS11 Studio Solari Stainless Steel Electric Single Oven
FBE0 (could be F8E0) has come up on the screeen - what does it mean? I can put the oven on but the temperature light is not coming on.
What does code f10 mean?
get a small oven thermometer and put it inside the over to check what temp it goes off at .many times it is a bad thermocouple .
Sep 25, 2015 | Kenmore Ovens
After selfcleaning tried to bake put when you push the bake button it says to unlock door, however door is already unlocked and open
During self clean the oven controller locks the door to ensure one does not accidentally open the door and get insured due to high temperature. The door lock mechanism is unlocked once the temperature comes to normal when self clean is complete. In your case the controller is still sensing high temperature but the door lock mechanism has been released. This could mean the controller is detecting incorrect signal. Try to turn the mains power to oven off and back on. If this does not make a difference then you need to check the temperature sensor or worst the controller needs to be checked.
As I do not have the model number of the oven it is hard to give further diagnostic information.
Aug 13, 2014 | Hotpoint Ovens
Oven wont light gaves F4
Hi, the F4 error code means Open or shorted oven temperature sensor (RTD)..
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Oct 20, 2010 | GE 30 In Freestanding Gas Range ...
I haVE A MODEL NO 47465 WHEN OVEN IS ON AFTER 3 MIN THE CODE F_2 COMES ON
This means that the oven temperature sensor is open. Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor.
Click on this link to see how to check the sensor temperature.
Thank you for using Fixya. Your generous rating will be much appreciated.
Oct 13, 2010 | Kenmore Ovens
My whirlpool oven has come up with code f 02 and wont work
Hello, the F02 error code on your oven means oven temperature sensor shorted and it can only be fixed by replacing the oven temperature sensor.
Thanks
Jul 14, 2010 | Whirlpool AKZ159IX Oven
What does f8e0 mean on my oven
Ok, this is very common with this model, and it is the main controller board. You need to call a service, man, and ask for a "Quote",
May 01, 2010 | Ovens
Why is error code F8E0 appearing on my Baumatic B205SS oven and alarm sounding
I have a B205SSA and the error code F8EO is appearing eveytime i have used the oven, i then have to reset it by turning off and back on again at the mains.
Any ideas? Cheers. Rich.
Mar 03, 2010 | Baumatic B205SS Stainless Steel Electric...
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Baumatic AS11 Studio Solari Stainless Steel Electric Single Oven Logo
415 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
