Question about iRiver H10 MP3 Player
Iriver h10 20 gb
When i put music in the iriver, after i disconnect from the computer a clock comes on but freezes. When i reset it all the music is gone. anyone know of a way to fix it?
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Then firmware upgrade
Posted on May 27, 2008
Iriver Clix 2 8GB connecting to PC problem
Usually it have to, but if is not use iriver plus software !! or see if u have drivers properly installed.
Apr 28, 2009 | iRiver Clix Digital Media Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Every time I turn on my iriver h10 it freezes on the artists and won't go anywhere. How do I fix this ? resetting doesn't help
not sure what's wrong but try this..
hook up your h10 via the ums trick...
The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
The UMS trick will also allow you to use your H10 with virtually any OS.
For 5/6 GB MTP Models
  • Take out the battery, wait a second, and put the battery back in.
  • You will see the message "UMS Mode" if you have done everything correctly. You can now let go of the "O" button.
For UMS Models UMS models do not need this trick because they are always in UMS mode!
download and run the free playlist maker software called EASYh10. It will scan the music files on the h10 music folder and save a new playlist to your player.
Mar 03, 2009 | iRiver H10 MP3 Player
Iriver H10 - DB Open Error
one idea...
connect player to your pc using the ums trick
What is the UMS trick on IRiver H10?http://www.zolved.com/synapse/view_content/5942/What_is_the_UMS_trick_on_IRiver_H10
This article tells you how to transfer music to your player The UMS trick is a great thing to know how to do. With it, you can transfer music, or treat your H10 as a harddrive to put anything you want on.
always in UMS mode!
---download and run the free playlist maker called easyh10. It will read the music files on your h10, rebuild a playlist and save it to your player.
Feb 03, 2009 | iRiver H10 MP3 Player
Iriver is froze
If there is a reset button, hold it down for bout a minute, then release it and see what happends
Jul 03, 2008 | iRiver T30 MP3 Player
Iriver s10 problem
there is a 'reset hole' next to the power on switch - you need a pin to push into the reset hole
I do not use the software that comes with the S10 - it always wants to go on to the internet and re download itself. If I want to copy music over I use windows explorer and copy MP3s into the music folder
Here is what I do when I need to reset - format S10 machine from windows
1. plug the S10 into the computer via the USB key
2. You should see the S10 in Windows Explorer as a portable flash disk
3 Right Click and select format - Warning! all data will be lost if you have not backed up!
4 In the File System drop down list select FAT (the default is FAT32)
5 Click start to format the device.
6 Once the S10 has been formatted unplug it from the computer
7 Turn the S10 on and scroll down to SETTINGS
8 Right click and scroll down to Advanced
9 Right click and scroll down to Format Device
10 Right click and then click OK to confirm
On the same menu as Format Device is Reset All Settings - I recommend you do this as well.
11 Plug the S10 back into the computer
12 When you look at the S10 in Windows Explorer you will see it has created some extra folders
13 drag and drop MP3 music files into the Music folder and away you go!
14 you can create additional folders in the Music folder if you want to organize your music
Jun 07, 2008 | iRiver S10 2 GB MP3 Player
Iriver Clix USB freeze
My screen also froze in the music menu, but when I connected to the PC, it was recognised and I could get into the files. Try resetting it by sticking a paper clip in the reset hole if you've not done it already. Mine's working fine so far....
Feb 17, 2008 | iRiver Clix Digital Media Player
Little Clock then freeze when it turns on
try the firmware update try connecting in UMS mode
Dec 18, 2007 | iRiver H10 MP3 Player
Iriver h10 20mb
download the firmware off of the iriver website. all of the files will be erased but when you recopy them onto the iriver, they will play.
Aug 06, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
