I need a repair disk for my hp pavilion ze5000s, but the hp website does not display any items listed under Purchase a replacement recovery disc online
    Brigadier General:
  • 10,406 Answers
Telephone HP, and talk to the "Parts" department.
They can find the part-number for the "System Recovery" CD-set for your model of HP computer.
Probably about $20, plus $20 for overnight-courier shipment.
Posted on Sep 29, 2010
Bootmgr missing on hp pavilion slimline s5503w
This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
  1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
    • Press the F11 key repeatedly while the computer is starting.
    • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
  2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
  3. If the error message persists, open the recovery manager screen as was done in step 1.
  4. At the recovery manager screen, press ALT + D.
  5. Enter the following text at the command prompt: bootrec /rebuildbcd
  6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
  7. To close the command prompt, enter the following text: exit
  8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
  9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
Hard disk error no recovery disc
@lizegim
HP laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work and gave you like an "I/O Error" or "Error 0x000000E" or something similar then that means that the HDD is already defective and needs replacement and you need to order the recovery discs from HP at 1-800-474-6836. If you're still under warranty, they'll replace the HDD and give the Recovery Discs to you for free.
Good luck.
Sep 06, 2011 | HP Pavilion A250n (DF253A#ABA) PC Desktop
Drivers hp pavilion xt395
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=88713#N178
These are the drivers on the HP website (For XP). If you don't see the ones you need, try doing a windows update.
May 03, 2011 | HP Pavilion xt183 xt395 xt512 OmniBook...
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
Need a recovery disc for Pavilion dv-5 notebook
Hi:
You most likely have a bad hard drive, and a disk set is not going to help you, though you will need it too.
What you need is a new hard drive, a copy of all the drivers for your laptop, which you can download for free from HP. If HP won't send you a copy of the recovery disk, you can use any OEM copy of the same operating system that your laptop has a sticker for, but you won't have all of your programs.
Nov 23, 2009 | HP Pavilion dv5-1140us Notebook PC
Reboot hp laptop dv9730us without recovery disc. Need to do this because I cannot access my wireless connection anymore. It always says it cannot connect. i tried it with other laptops and it always...
You can restore your computer to the Factory State without the disk, provided you still have the recovery partition created by HP. Restart your machine, and tap F11 until you reach the Startup Repair. Cancel the AutoDetect and go to the list. You'll find an option that relates to restoring your PC to Factory state. Remember, you'll lose all data doing so. Let me know if you need more help
Oct 02, 2009 | HP Pavilion dv9730us 17" Notebook PC -...
HP Pavilion zv 5316 us Recovery Discs
fixha sells you nothing, its just chat box free.
and is not HP,why ask here.
good luck finding free disks.
good luck matching exact model, that 's right exact.
and never post email addresses, unless getting SPAM for 1000 years is fun, or safe.
why post here at all, ask real HP>
https://h30434.www3.hp.com/
HP does not sell disks on non-supported PC,s (too old)
so ask them , or find them on ebay, or use craigs list
and post WTB wanted to buy, this is not buy sell forum here at fixya but good luck if you do get offers.
see the 2 links below, that are 2 ,HP recommended 3rd party selles
of install disks.
by the way, if buy disks from random sells, they will be infected.
if XP , x1000 that. idea.....
http://pcdied.com/HP-OS-GET.html
Jul 17, 2017 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
How do you restore factory settings on a hp pavilion zv5000
I have the same problem - Best Buy does not give back-up discs,..but will allow you to purchase them (not cheap). I was used to them coming with my computers.
Apr 24, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
