Question about HP Color LaserJet 2600n Printer
I am getting a black/gray shadow of other parts of the page down the right side of each printed page
    Scholar:
  • 78 Answers
This is called backgrounding. It is a common issue with this machine when you print past the reccomended out or use inferior remanufactured carts. This is usually either a poorly adjusted doctor blade in the cartridge, or if it is an HP cart, it has a prematurely full waste bin and is transferring waste toner to the page. Either way, replace the cartridge.
Posted on Sep 29, 2010
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
Light print on right side of page
from what you are saying, if color is fine and black is not, its most likely the black drum that is the problem. the toner is part of it. try taking the black toner out and shaking it, and putting it back in, if it still does not help, most likely it is the toner/drum.
thanks adi
May 05, 2009 | Epson AcuLaser CX11N All-In-One Printer
Shadowing/graying with printing
Hi fa1103:
Gray background
1. Do not use media that has already been run through the printer.
2. Try using a different type of media.
3. Print a few more pages to see if the problem corrects itself.
4. Turn over the stack of media in the tray. Also, try rotating the stack 180°.
5. Open the Configure Device menu at the printer control panel. On the Print Quality
submenu, increase the TONER DENSITY setting. See the user guide.
6. Make sure that the environmental specifications for the printer are being met.
try these steps to see if they work for you.
pdouglasss
Dec 23, 2008 | HP LaserJet 2420dn Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Black Lines running down the right side outside of the print area
It may be the fuser. Take it out and inspect the roller on it:
  1. Switch off the device, disconnect the mains plug and wait for 30 minutes before continuing.
  2. Ensure that the bypass tray is closed, or you will not be able to open the front cover.
  3. Open the front cover by pressing the release buttons as shown.
  4. Pull the front cover down towards you.
  5. Disconnect the green plug - squeeze the sides of the plug and pull.
  6. Push the left and right levers outward to unlock the unit.
  7. Pull the unit towards you as shown and lift it clear of the device.
  8. Check the roller for wear marks, If so replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 21, 2008 | Ricoh Aficio CL3500N Laser Printer
Shadowing
GOOD DAY ND GOOD LUCK;
TRY THIS, IT WILL CORRECT CONCERN:
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
CONDITION:
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
CORRECTION:
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  1. BEFORE CONTINUING: CONFIRM THAT THE R, G and B DRIVE ARE SET AT 40.
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
  5. I HOPE THIS WAS HELPFUL, big IRISH.
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Printing a shadow
i would redownload latest drivers 1st ok then dop a nozzel clean up then maby cheak status of black use only oginal ink parts not generic
Feb 03, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Laserjet 1320 - Gray bars printing on sides of paper with dark dots
It sounds like a defective toner cartridge. Try replacing it. If that does not cure the problem, then the fuser assembly needs to be replaced, in which case it is probably cheaper to buy a new one.
Good luck
John
Dec 31, 2007 | HP LaserJet 1320 Printer
HP Color LaserJet 2600n Printer Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
