Question about GE 30 in. JGP326 Gas Cooktop
The electric igniter sometimes doesn’t stop clicking when the burner is off.
  • GE Master
  • 3,740 Answers
Hi and welcome to FixYa I am Kelly. The igniters are controlled by a switch mounted on the face of the burner control vbalve. The switch operates by rotating a ceramic cam against a movable copper strip of wire to contact a fixed contact. What happens is that sometimes the movable copper wire strip gets bent and stays in contact with the fixed contact. These switches are not repairable and must be replaced when they fail.
I used this model as a reference fopr your part as you provided an incomplete model number in your post. JGP326BEV1BB
The switch is common to all models and can be found as item 323 here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=214745&diagram_id=20726625#d20726625
Close up view:
http://www.appliancepartspros.com/part_details.aspx?part_id=3191247
There is one switch per burner control. Replacing this switch will correct the problem.
Thanks for choosing FixYa.
Kelly
Posted on Sep 29, 2010
Have trouble starting gas burners on nobel fse90-1. Is there a trick to starting the burners. I need serious help before I go mad!
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good "blue" arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 20, 2010 | Cooktops
All 4 electrodes spark when only one is turned on
Jul 20, 2010 | GE 36 in. JGP628 Gas Cooktop
Ignitors clicking
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
On our 6 burner gas coocktop, the right two burners don't light
May 10, 2010 | Thermador SGS36GS Gas Cooktop
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
Spark ignitors went on stove top
Jan 09, 2010 | Whirlpool SCS3014LS Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Viking cooktop gas unit ignition clicks on all burners when I use
Dec 05, 2009 | Viking 37 in. DGCU165 Gas Cooktop
Ignitors are not working
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
1 burner wont stop clicking on miele cooktop km 344
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
May 06, 2007 | Miele 36 in. KM342 Gas Cooktop
GE 30 in. JGP326 Gas Cooktop Logo
192 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
