Question about ViewSonic VA1912w 19" LCD Monitor
It doesn't turn on my monitor, lights always blinking.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
When it have this kind of error is a problem of the powerboard.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Posted on Apr 04, 2014
  • 137 Answers
If this is an amber light, It reflects an Hardware malfunctionality.
do a test if it works it is fine else you need some one who can repair your Laptop.
remove cables and sakeep pressing power button for 3 mins.
insert all the cables back. it may work.
Posted on Sep 29, 2010
Monitor doesn't turn on
1ST CHECK POWER CORD.
2ND CHECK CONNECTION ON BACK OF PC
3RD HAVE YOU INSTALLED, DELETED OR REMOVED ANYTHING FROM YOUR PC PRIOR TO THE MONITOR SHUT OFF ON YOU
Feb 17, 2013 | Dell ST2420L 24 inch LCD Monitor
I have a HP Pavilion Slimline s3700y that doesn't always boot. Power is getting to the computer; the light on the back lights up as well as the lights on the front. However, power doesn't seem to...
If you saying "doesn't always boot", most common would be motherboard...
If your motherboard still beeps, then probably some other components has the problem like RAM, GPU card etc., depends on your motherboard.
Hope that give an idea...
Jul 11, 2011 | HP Pavilion Slimline s3700y Desktop,...
After a storm the other night my Proview PL866s amber light is blinking - however when I press the amber button (which usually turns green and then it works) nothing is happening except blank screen and...
If this happened after a storm, the monitor may have been subjected to a power surge, which unfortunately might have killed it.
If you have another monitor (or a friend who has one) try plugging that other monitor into your computer. If the second monitor works, yours will need to be replaced as the input was probably destroyed by the power surge.
If the second monitor also doesn't work, there may be a problem with your computer, most likely with the power supply (this is the part most often damaged by a power surge). You may want to have it examined by a professional computer repair person at that point.
Hope this is helpful!
May 16, 2011 | Proview PL866B 18 in. Flat Panel LCD...
No picture. Monitor blinks 4 reds. Tv would come on for a few seconds then turn off. Now nothing but blinking lights. what do I do. Thanks
You have may be broke the system cable, the dvi-d cable is broke...
In my pdp-5030hd have the same problem, probe changing the only the dvi cable and works perfect...
The monitor blinks 3 red and the 4 blinks still in red...
Now i will try to put in the dvi-d input another source like a pc...
You need always the Pdp03u box for control...
Sep 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
ViewSonic VA1912w 19" LCD Monitor Logo
170 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
