Sony LCD tv # KDL-52W3000 gets a green "cellophane" like 6" stripe down thru screen/ left of center/ top to bottom after it warms up. What module is the likely cause??
  • 10,594 Answers
I'm afraid it sounds problem of lcd panel (screen) itself that need to be replaced to fix the issue.
If tv is still under warranty then call to number written on tv warranty documents to get lcd panel replacement without cost.
Some times T-Con board found as problem cause, t-con board is basically part of lcd panel but some parts stores sell it separately and you can replace t-con board that might solve your tv problem.
If you are familiar with electronics stuff repair then can attempt to replace t-con board and if you have no prior experience then I would recommend to have tv repairman services for that.
Required T-Con Board is available with shop jimmy, click that link to view board image and price info.
Again I would repeat, problem seems with lcd panel (screen) and t-con board replacement might fix the problem.
If tv is under warranty, do not attempt to fix it, just call number written on warranty papers and ask for warranty cover.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 01, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the inverter board is fine so it is either the T-con board in the unit has gone bad and/or it is not getting the required 12vdc from the power supply unit. If you have knowledge of internal circuitry of the unit then you can open the back of the unit and check the T-con board which is the last board before the LCD panel. Usually it is available with the LCD Panel. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when in off position. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 29, 2010
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
White flare top left of screen sony bravia ldl-52W3000.
The capacitors at the main power supply regulator board should be checked and replaced. If you are not familiar with electronics, do not attempt to repair! Whether you suffer fatal electrical shock! Instead, contact the nearest service center!
Jan 20, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a sony 52 inch bravia kdl-3000 and there is a line on the left side from top to bottom. if its the panel that needs to be replaced what would it cost.
Sony panels run around $1,500.00 and up. Go to Face Book and type in (I Have a Defective SONY TV.) Click on LIke So you can Post Your Problem. Their you can get a replacement TV From SONY !!!! If it turns out that you do have a Bad Display Panel.
Oct 18, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My Sony Bravia 46" has a 1" thick black line horizontally thru the middle of the screen. It separates the top and bottom. Has anyone seen this happen before?
It sounds lcd screen problem and lcd panel (screen) will be replaced. Please check with local tv repair shop or nearest Sony service center for lcd screen replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40XBR3 40 in. LCD HDTV
The picture is too big for the screen and i can't get it reduced
Change aspect ratio of screen through screen format option in Menu.
Hope this will fix your screen size issue in Sony KDL-52W3000 tv.
Thanks.
Dec 27, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a sony Bravia KDL-52W3000 LCD tv. Approx.
I have the same tv with the same problem. My tv is about 3 1/2 years old. I took it to the shop yesterday and today they told me that I had a bad lcd panel and a bad FL1 circuit board. They also told me it was going to be $3800.00 dollars to fix. I am now on my way to buy another tv, needless to say it will not be a Sony. Sony knows about this problem and refuse to do anything about it. Good luck.
Nov 26, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
My Sony BRAVIA KDL-46V3000 Television has messed up colors on left side when first turning it on.....after 5 or 10 mins the picture is normal.. Also without turning on the receiver (only TV) can't select...
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Nov 15, 2009 | Sony BRAVIA KDL-46V3000 Television
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Picture horizontal lines!!
try call sony get one time warranty.maybe lcd panel bad or call bestbuy in home service
Aug 14, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Lines across tv
try cleaning T-CON Board to Lcd panel cable
Jul 23, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
