Question about iLO (2 GB) MP3 Player
Flashing Intro. but no music
My MP3 player is flashing the iLo intro. I have put numerous batteries in it thinking that the batteries were dead. However, they were brand new. What is wrong?? I have also connected to computer and the music is still on the player.
  • sup04206 May 25, 2008
    My ILO also flashes the intro, but will not turn on the rest of the way. The only way I can get it to turn off is to push down the key lock switch. My ILO is only 3 months old. I have also changed batters and looked very closely at the switches. No luck.
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 26, 2008
How do i get my mp3 out of intro mode ???
During music play back tap the Quick Option menu. Then choose Repeat Mode and change it from Intro mode to All or Repeat All.
If you haven't user guide you can download it:
http://www.cobyusa.com/files/manuals/MP826_MN.pdf
Thanks.
gylacz
Aug 12, 2011 | Coby MP826 MP3 Player
Stopping the "intro" mode on the music player
i think you mp3 is now carrying of virus! you can reformat your mp3 to software with twister series!
Oct 14, 2007 | Audio Players & Recorders
I can only get my mp3 player to play the song for 10 sec???????
Your player is in "intro" that means all the tracks will be played for 10 sec only. This feature can be swithed off:
On the main menu, select the "Settings" item and press the MENU button
to enter the system settings mode.
Press the PREVIOUS/NEXT button to select setting item and press the
MENU button to confirm or press the PLAY/PAUSE button to
cancel/return.
You should find Music then Repeat mode, here you can select another mode then "Intro" for example Once, Repeat Once, Folder...
I hope I could help.
Thanks.
gylacz
May 15, 2011 | Sylvania SMPK2072 MP3 Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
SONG ONLY PLAYS FOR 30-40 SECONDS
pure,
Most probably you accidentally switch the play mode to " INTRO" check your display if it does indicate Letter " I" in it. if does any music you play will be in "INTRO" mode. IF you still have the manual for your player check the 'PLAY MODE" setting. From this setting you can choose play mode from "FOLDER" "NORMAL" "INTRO""REPEAT 1" REPEAT ALL" to play in continuously select "NORMAL" mode.
I'm not sure if your player do have the same procedure in changing play mode . But try this , while on play mode . Press menu and a dialogue box will appear scroll and select "NORMAL"
cheers,
mark
Feb 04, 2009 | GPX MW3836 MP3 Player
MP3 player plays 10 seconds of a song and stops
Your MP3 Player is in the Intro Play Mode. This is just a preview mode where it'll play the beginning of a song. If you hit the menu button (but don't hold it) while the song is playing, it should bring up the music submenu. From there, go to Play Mode and select any mode except Intro. Generally though, you'll want it on Repeat All or something of the like. Random is also good if you can't figure out what to listen to.
Hope this helped :)
Jan 10, 2009 | GPX ML648B MP3 Player
Mp3
Oh on the first ten second thing. Do you accidently have it set on INTRO? Cux i accidently did that also. So check that.
Dec 26, 2008 | Element Electronics Zr-Element Digital...
Amp'd turns on but turns off after intro.
I had this problem too, I was going crazy and worried about it, your iDog AMP'D Just needs new batteries, to change it, unscrew the metal screws that are located under it's back legs, and replace the old batteries with three new AA ones. Make sure they are good batteries!
Hope this helped!
Oct 16, 2008 | Hasbro I-DOG AMP'D
Flashing ilo.
I found that connecting the MP3 player to the computer with the patch cord causes the player to reset and eliminates the problem. It only takes a few moments,just disconnect when the pc tells you it is safe to remove the device.
Jan 19, 2008 | iLO (2 GB) MP3 Player
Downloaded music onto it then it just keeps flahing ilo
OK this is an "Internal" problem and it must be returned to the supplier/manufacturer for repair/replacement. I have seen this countless times B4.
Jul 29, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
35 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Michael Vincent Cruz
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
