Question about GE Microwave Ovens
I purchased a GE microwave oven in March 2008. It was working just fine, then I went to use it again, and it will not heat anything. The light comes on, the turn table turns, but does not heat naything. It makes a very loud buzzing noise as well. I never put anything in that doesn't work in it. Any suggetions or is this covered with a warranty?
  • GE Master
  • 9,086 Answers
I'd say you have a bad magnetron, but it will have a full one year warranty on parts and labor.
Let GE fix it for you free. GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 27, 2008
"door error", "start?" - When
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Nov 29, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating.
1 thing here you can check yourself. You need to remove the cover of the microwave. Make sure it is unplugged first. To remove the cover there should be a series of phillips head screws on the backside of the microwave. Once the screws are removed then you need to lift the back of the case towards the front there is a lip at the front that holds the front down that is why you need to lift the case from the back. Once you have accessed the inside follow the powercord from the plug into the microwave along this cord you will see a fuse. Very IMPORTANT do not touch both sides of the fuse holder at the same time. There is a charge stored in the microwave that will curl you hair remove this fuse with a fuse puller (purchased at an auto parts house) Take the fuse to an appliance parts house for replacement. Should be in the area of 10.00 or so. Replace the fuse put the casing back together and try the microwave. If it doesn't work then the magneto or magnatron whichever the machine has is blown and in that case it is cheaper to buy a new microwave
Good luck hope this helped you some
Dave
Jan 18, 2010 | GE JVM1540DM Microwave Oven
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Sep 22, 2009 | GE JE1640 Microwave Oven
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
New Microwavbe that will not work.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Dec 28, 2008 | GE Microwave Ovens
Slow turn, hot food
underneath the deck is a geared motor that turns the platter. check for non lubricated bearings or slipping gears.
Aug 22, 2007 | GE JVM1440 Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
75 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
