Question about Lexmark X1240 All-In-One InkJet Printer
How do I install my new black cartridge? I mean, where does it go? jessicah@ripnet.com
    Brigadier General:
  • 10,406 Answers
Turn the printer on.
Lift the lid that covers the print-head mechanism.
Look on the inside of the lid for instructions.
Wait 10 seconds.
The print-head should slide to a position from where you can "unlock" the ink-cartridge from its socket (sometimes a lever, sometimes just push firmly "down" on the cartridge), and then to gently slide/lift it out.
Posted on Sep 29, 2010
  • Official Brand Answer
  • 3,344 Answers
Perhaps the Lexmark X1200 Series User's Guide will be able to help you. Download using this link: http://bit.ly/d2qaOa. Scroll to page 13 for instructions on how to replace the print cartridges.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
HP 4015x and I get an insert black cartridge error. Not sure what I should be replacing on it or what to check on the printer.
Thank you for contacting FixYa with your printer inquiry.
This error is most common when your toner cartridge has reached it's end of life. Sometimes it will alternate with "This cartridge has reached a low threshold error" which indicates you can keep printing but need to order a new toner cartridge. See page 155 of your support manual for more on this error.
See page #117 of your user guide for toner installation instructions. http://h20000.www2.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
If you have installed a new toner cartridge and receive "Remove Shipping Lock Error" that means you have not removed the protective strip on page 118 step #5.
You can order new toner cartridge from HP PartSurfer or retail merchant where printer purchased.
http://partsurfer.hp.com/Search.aspx?SearchText=CB511A CC364-67902 Black print cartridge - Prints approximately 24,000 pages per cartridge CC364-67901 Black print cartridge - Prints approximately 10,000 pages per cartridge
Hope this helps helps. Please keep us updated and remember to rate this answer.
Mar 30, 2011 | HP Laserjet P4015x Printer
Installed new black cartridge yesterday,now today when I go to print it says cartridge error check documentaion,which Im not sure what they mean ? please help
Hi! Please remove the black cartridge and shake it a little. You need to do this when installing a new set of cartridges. Hope this helps and thank you for using FixYa!
Aug 31, 2010 | HP Officejet 5610 All-In-One InkJet...
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
New black cartridge installed in MP780 Prints
This simply means that black ink is installed but not CHARGED properly. What you see in a color printing has actually no black color in it but a combination of the hues of blue and yellow and magenta; though it appears black or dark.
Now, use your printer's maintenance utility to do Head Cleaning. To do this, click Start => Settings => open your Printer and Faxes, then right click on your printer's name. Then click on Printing Preferences. Now in the window that opens, click the Maintenance tab and do Head Cleaning. (In some printers, maintenance is called Toolbox)
Dec 20, 2009 | Office Equipment & Supplies
My printer says install magenta what does that mean
It means for you to install the magenta ink. Magenta is a color. You have 4 colors. Yellow, magenta, cyan, black
Oct 14, 2009 | Brother Multi-Function Center MFC-240C...
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Installed new black ink cartridge on Kodak ESP7. Cannot get rid of Error Message (saying need to install black cartridge!). Help!
Kodak had a batch of bad cartridges, I got 3 of them. All come from China. I used the online chat to describe the problem. They promised to send me new cartridges.
Jack
May 11, 2009 | Office Equipment & Supplies
Message : Black ink cartridge empty , order new one
Haven't found a fix as of yet ...Will keep looking .. $15.00 for expert help is half the price of the printer. I'll keep searching , thank you !!!! In the mean time I'll tell everyone about Lexmark and how they handle their ink cartridges
ummyguy
Aug 20, 2008 | Lexmark Z1300 InkJet Photo Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
