Question about Microwave Ovens
Were can I locate the user/owner manuals for my Culligan under counter RO water filter unit model no. CTT35ST3.0 Thank you. Laura
Need user manual PDF
MICROWAVE OVEN - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesWe have provided many important safety messages in this manual and on your appliance. Always ... Read all instructions before using the microwave oven.
[PDF]Operating Instructions - Panasonic
service.us.panasonic.com/OPERMANPDF/NNSN797.PDF
PanasonicWe have provided important safety messages in this manual and on your appliance. ....Thank you for purchasing a Panasonic Microwave Oven. WARNING ...
[PDF]INSTRUCTION MANUAL Microwave Oven - akai.com.ro
www.akai.com.ro/resurse/produse/manuale/am820crl_manual.pdf
exposure to microwave energy. 3. Warning: Only allow children to use the oven without supervision when adequate instructions have been given so that the.
Free Microwave Oven User Manuals ' ManualsOnline.com
Jan 12, 2016 | Microwave Ovens
The water in our culligan water cooler keeps turning into ice and will not come out of the unit. How do we prevent it from freezing?
There is a thermostat that is to shut off the cooler. It has gone bad and will need to be replaced. Often the Culligan contract includes the cooler maintenance and repair...check with them, they should fix it for you.
heatman101
May 19, 2011 | Microwave Ovens
My husbands wants to know how to clean the air filters that are under the spacemaker icrowave oven and above the stove ?
If your unit is venting to the outside, you would be using one or two grease filters, which can be cleaned, usually with warm soapy water.
If your unit is set to recirculate, then you should be using a charcoal filter, which cannot be cleaned, and must be replaced.
Details and instructions are to be found in your owner's manual.
If for some reason you don't have yours, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including filters) by entering your full model number here.
Apr 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800 Adora Microwave (manufactured in 2004) and the light bulb went out but I can't located it to replace it. Where is it located? Thanks
If it is meant to be user replaceable, then your owner's manual will cover it.
If not, then you may need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Either way, you can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 17, 2011 | GE XL1800 1100 Watts Microwave Oven
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Tappan over range has no heat!
You have a bad high voltage diode, bad filter capacitro or a bad magnatron. The diode and capacitor does not cost very much. You can get them at www.mcmelectroncs.com . Replacement would mean removing the unit from under the counter, remove the case. Locate the diode and capacitor. They should be near the power section and the diode is attached to the chassis and one side of the filter capacitor. After replaceing both parts if the unit will not heat you would need a new magnatron. The part is fairly expensive but depending on the cost of your unit it may pay to replace it. Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Feb 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need User Manual for my microwave
Just click below;
Whirlpool Microwave/Hood Combination manuals, user manuals, owners ...
Whirlpool Microwave Hood Combination MH7140XF, YMH7140XF User Guide Get This Manual .... Please help find the manual for this Black & Decker Convection Oven ...
Hope this may help you; DON'T FORGET TO RATE:
Sep 06, 2008 | Whirlpool MH7140XF Microwave Oven
Emerson mw8107wa user manual
This manual is available on FixYa, see link below: http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318 Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 08, 2007 | Emerson MW8107WA Microwave Oven
Microwave Ovens Logo
123 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
