Reel to reel belt replacement
Need suggestions on how to replace belt.
  • 2 more comments
  • chas24 May 25, 2008
    Have an old TEAC AR-40s reel to reel tape deck. Bought a new belt, but not sure how to install.
    Any suggestions?
  • chas24 May 29, 2008
    Hello - Well, I got the belt installed on my AR-40s Teac reel to reel tape deck. It's a *****.....
    First remove the top plate (remove any reels. the idler pulls up - (I tried to unscrew metal top. Don't try!) I then had to take out 4 phillips screws from the top of the deck, and two from the back.
    I also took out four from the sides. (not sure I needed to...) I also removed the bottom fibre cover - 8 small phillips wood screws. Then I pulled out the deck unit ( which has an electronic section attached). Because of two cable assemblies, I could only pull out a short distance. VERY heavy. Anyway, stand the deck on end, and you can see the bottom of the main flywheel shaft. It has a ball shaped end, and just enough clearance for the belt to go under. I used a thin, stiff wire - bent a small hook- to grab the belt. Snake the wire from under the deck, under the flywheel - it will come out from under the wheel to the top of the deck.I then hooked the belt over the motor pulley, (to keep it from hanging down) and grabbed the belt with the wire hook, and pulled the belt under the flywheel. Be sure to first thread the loose belt between the wheel mounting post and the large flywheel, otherwise the belt will be outside the post instead of going directly to the motor pulley.
    THEN comes the fineigling - you have to work the belt under the bottom of the flywheel shaft and push up towards top of deck. Then hold the belt against the flywheel and work the belt around the wheel.
    Question - the drive motor has two pulleys with different diameters. Is that for 50 or 60 cycle power? Or what.....?
    Have yet to test unit for speed. That may answer my question.
    Hope this helps anyone attempting to do this. Not sure this procedure works for the 4010s.
    Charles
    Found a solution - anyone wants to know, e-mail me, or post your request.
    This stupid website doesn't have a way to post a solution to your own question!!!
    I wrote a complete solution, but it disappeared. Too tired to rewrite
    Charles
    I apologize to the fixya website - it DID post my solution. I'm still new to websites!
    Charles
  • 975 Answers
ITS been a long time since I replace BELTS for VCRs and REEL to REEL , what I suggest is , if youre very handy with tools and know your way around electronics, you can perform the replacement of the belt, open REEL TO REEL to access where BELT is located , study how is install , and remove ONLY the parts thats blocking you to remove OLD belt,memorize the order which you remove the neccesary parts
then install new belt , and install back parts in the order that was remove , hope this helps , good luck , AJ
Posted on May 25, 2008
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Gx-77 Akai reel to reel tape deck -belt
G'day Chidu
You can buy a replacement belt kit with the correct belts for your model from here
Thanks for using FixYa, a FixYa rating is a great reward for locating this part for you. Good luck with the repairs, and happy listening.
regards
robotek
Posted on Sep 11, 2008
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
  • 259 Answers
SOURCE: where to buy replacement belts for a Akai model M3
Try this site:
http://www.turntableneedles.com/
Posted on Feb 28, 2010
Testimonial: "Thank you very much. Appreciate the good info."
How to replace belt 1250 reel to reel tape deck
Yes, Bob can do it, Russ in New Jersey can do it and I am in Chicago.
It is not hard to replace belts but that is not the only thing it will need. It is likely going to need brake pads, lubrication and some other parts to be recondition like the capstan shaft. Calibration would be needed as the age of the components will have changed. Changing just the belts just gets it going.
Apr 18, 2014 | Audio Players & Recorders
The rear double seat of my 2013 Mitsubishi Mirage won't raise after folding down due to not enough play in the middle seat belt. How can I release the seat belt to lift the seat again?
sorry but seat belt reel is jammed ,,,, find reel and prob will have to replace it ,,, dont play with safety belts or reels they are too important
Dec 01, 2013 | Cars & Trucks
I have a Teac A-1500 reel to reel tape recorder and need a drive belt for the capstan, Can you help me?
Contact: pjheiland@hughes.net He can supply drive belts for Teac reel to reel recorders and other manufacturers units.
Mar 31, 2011 | Teac Audio Players & Recorders
Instructions for Teac Tascam 32-2B belt replacement. I have had this Reel to Reel Tape Recorder for a number of years and the belts have now perished. I have purchased replacement belts on ebay but could...
Ebay is the worse place to get belts- why do I know this? Well, as a servicer I am constantly replacing belts that are from E bay when clients can not get their decks to work with those wrong belts. While the counter belt is not critical the capstan belts are in a dual capstan system. The 32-2B is a X10 derivative so it will need proper servicing to work well. I am in the Chicago area and work on decks all the time as Skywave Tape Deck Repair just google it.
Mar 19, 2011 | Teac Audio Players & Recorders
I have a single cassette deck Philips DC 900 when you hit the play button,it plays for about 5 seconds then stops and head retracts. Belts have been replaced
It's not seeing the takeup reel turning.
Either the takeup reel isn't turning or the takeup reel sensor has malfunctioned.
Check the belt to the takeup reel by doing a fast forward.
Will it fast forward? and is the takeup reel spinning during playback?
Feb 27, 2011 | Audio Players & Recorders
How do i fix the seat belt rewind on a 1999 dodge ram 1500. The belt was twisted so i removed it from the reel. In the process the reel spun releaving the spring. I tried to rewind the reel but i can't...
You may have to take this one in. It is an inertia reel and is made to retain tension at all times, if you relieved the tension, reel is "sprung" and will have to be completely disassembled, in some accidents if the seat belt is used in the impact and impact is severe enough, inertia reel has done its intended job and needs to be replace entirely.
Jan 04, 2010 | 1999 Dodge Ram
G'day Chidu
regards
robotek
Sep 09, 2008 | Audio Players & Recorders
Hi jvanheul
regards
robotek
Jul 18, 2008 | Audio Players & Recorders
Mar 25, 2008 | Audio Players & Recorders
1,509 people viewed this question
 Grubhead
Grubhead
