Question about Car Audio & Video
Don't know how to put the spark plug wires back the distributor cap on a 1990 honda accord
  • 4 Answers
Try the other end, use masking tape and marker to number the wires before removing, leave them in the cap and lay them on the floor to match up the lengths, install the new wires in the new cap one at a time and number them, 4 cyl. start at drivers side 1-2-3-4. on V6 drivers side 1-3-5. pass side 2-4-6.
Posted on Sep 29, 2010
My 1990 honda accord keeps backfiring after new spark plugs wires what do i need to do
sounds like you have the wrong firing order for the spark plugs.
The firing order is 1-3-4-2 going clockwise around the cap.
Nov 02, 2012 | Cars & Trucks
1990 honda accord will turn overbut wont start
DO A SMALL TUNE UP REPLACE SPARK PLUGS AND WIRES, REPLACE DISTRIBUTOR CAP AND ROTOR, REPLACE FUEL FILTER AND AIR FILTER. IF YOU ARE GETTING FUEL AND SPARK. EITHER IGNITION OFF OR VALVE TIMING OFF YOU VECHICLE HAS A TIMING BELT AND TENSIONER IF TIMING BELT SLIP TIMING IT WILL THROW OFF VALVE TIMING MAKING IMPOSSIBLE TO START CAR.
Nov 01, 2011 | 1990 Honda Accord
My 1990 hond accord will turn over but wont start can you please help
MAKE SURE SPARK PLUGS AND WIRES IN GOOD CONDITION, REPLACE DISTRIBUTOR CAP AND ROTOR,CHECK FOR SPARK AT SPARK PLUGS,IF YOU DONT SEE SPARK CHECK TO SEE IF POWER GOING TO COIL IF NOT CHECK IGNITION FUSE.IF FUSE OKAY AND POWER GOING TO IGNITION COIL,COIL FAULTY OR IGNITER UNIT FAULTY. CHECK FOR FUEL PRESSURE MAKE SURE FUEL FILTER BEEN CHANGED.FUEL PRESSURE SHOULD BE 40 PSI. IF YOU GETTING SPARK AND FUEL. YOUR IGNITION TIMING OFF OR VALVE TIMING OFF DUE TO A WORN TIMING BELT.
I have a 98 honda accord 5 spd it has a 4cyl motor vtech i just need to know how to fix a miss fire in cylinder 2 and wich one is cylinder 2
Cylinder #2 is the the second spark plug counting from the right to left.
EX.Below are spark plug on engine
engine
' (oil cap) '
' (4) (3) (2) (1) '
'_________________'
Your misfire can be cause by couple of things but the cheapest way that you can try to fix your car is to do a tune up by replacing:
1)all spark plugs
2)do a oil change
3)spark plug wires
3)distributor cap and rotor
note misfire can be cause by:
1.bad gas
2.spark plug and/or wire
3.distributor cap and/or rotor
4.valve adjustment
5.injector
6.off timing
7.ECM
8.bad wiring(power, ground or feed line)
Jul 08, 2011 | 1998 Honda Accord
Not sure how to replce spark plug wires from the distributor need help please send info
change one spark wire at a time on the distributor.buy new set of spark plugs wires remove them from box.match old wires with new wires to use the correct length to each cylinder.now if you need to change distributor cap.mark location distributor cap.number tag plug wires on the distributor cap so you can remove plug wires on distributor cap so you can replace cap and rotor and put wires back on the distributor cap in correct place.remember change one plug wire at a time so you wont get confuse.
Apr 15, 2011 | 1992 Ford Tempo
Maintenance required light is orange and it sounds rough when I drive. I did change the oil. But I don,t know what else it could be. can you Pleas help me. I have a 1991 Honda Accord
You should also change the fuel filter park plugs plug wires distributor rotor and cap and change the air filter.Put a bottle of injector cleaner in the fuel tank also.If you have more question write back .Thankyou
Oct 19, 2010 | 1991 Honda Accord
What is a ignition output signal on a 1990 honda accord , recently replaced entire distributor thats the coil , sensors, cap, rotor, ignitor. etc. i have power at the distributor, power at the coil , but...
Most of the time these distributor come with the ignition module did your, if it did and it has not been that long and is still under warranty, have it replace, if it did not come with one replace module.
Jun 11, 2010 | 1990 Honda Accord
No fuel no spark 1990 honda accord
other than the timing belt being broken, it sounds like the crank sensor in the distributor. get a used distributor. but first pop cap off and see if it is turning with engine.
May 25, 2009 | 1990 Honda Accord
Honda Accord- no fire
I replaced the main relay assembly.
May 16, 2009 | 1990 Honda Accord
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
