Question about Pentair Minimax NT Heater
Where is the best place to geta pentair mini max nt 400 control board (472100)?
    Novelist:
  • 116 Answers
Best bet is to call Pentair and ask for a dealer that carries the part. Then call the dealer and ask if they have it, can get, what it'll cost etc. Often times local part suppliers won't keep the circuit boards in stock if carried at all. So best to call first. Pentair's number is: (800) 831-7133, andf their website contact info is: http://www.pentairpool.com/pool-owner/contact-us/index.htm
Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good feedback if you found this helpful. Thanks, and good Luck!
Add a comment
Posted on Sep 29, 2010
Why is there no display on my pentair mini max nt?
is ther power going to it if so check power supply or main power conversion board
Aug 22, 2014 | Pentair Minimax NT Heater
Pentair Mini max my power light comes on but my pressure sw does not light up
if pressure switch does not light that means no pressure either water flow or a bad pressure switch you can jump the wires on the pressure switch but be very carefull if it does start make sure it does not bang or make noises
May 14, 2014 | Pentair Minimax NT Heater
When I turn my mini max plus 400 heater on it clicks then nothing happens, what's up with that
If it is clicking it is trying to fire (calling for heat). This indicates that the internal safety loop Tstat, and IID are working. It is either a bad gas valve, your ignition wire, or lack of gas. If the gas line had been open for servicing for any length of time it can take a while for all the air to get out. Best call out a tech to do the repair, you are literally playing with fire.
May 15, 2012 | Pentair Minimax NT Heater
I have an mini max nt w 6800 controls ignitor
The voltage to this ignitor should only be 120 volts. If you are getting 240 volts to the ignitor, there is something really wrong with the wiring to the heater or in the heater.
Jul 27, 2011 | Pentair Minimax NT Heater
My mini max NT 400 shows it is not getting power. Nothing on the display is lit. Not sure where to start, any help is appreciated. Thanks
Start at the begining, make sure you have power going to the heater and check to see if it is 110 or 220v. If you have power and it is correct the next stop is your transformer and how it it wired. You should have a diagram inside the main power junction box for the heater. If you have good power in to the transformer and 24v coming out it will be in your safty circut. Roll out switch and pressure switch are good places to start. The main power or transformer are probally where you should look.
May 09, 2010 | Pentair Minimax NT Heater
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
No display lights
Make sure you have 24 volts coming from the transformer...Alot cheaper part.
Jun 01, 2009 | Pentair Minimax NT Heater
My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Apr 16, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
138 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
