Question about Acer H233H bmid Monitor
I recently bought the H233H monitor to use on my new Win7 PC. When I am viewing anywhere online all the background stuff shows up pink. Replies on Facebook are boxed in pink as well even though every other graphic is fine. I thought that I had done something in Win7 to cause this but when hooking up a different monitor it works fine.
    Brigadier General:
  • 10,406 Answers
So, your "new" monitor is the only monitor with the problem ?
Exercise the WARRANTY for the Acer monitor, and get it replaced/repaired, at no cost to you.
Posted on Sep 29, 2010
How to make icons show up on desktop hp2009m
If you can see your cursor on the screen and you are able to make a right click and refresh it then make a right click anywhere on the desktop background and check the option show desktop icons has a check mark on it. You can also find show desktop icons under view option.
May 09, 2014 | HP 2009M Monitor
Tip
How to change the desktop background image.
There are two ways in which to set your desired image to your desktop background.
Option 1
1) Fistly locate the picture you want as your desktop background.
2) Then double click the image to take you into Windows Picture and Fax Viewer as the default picture viewer. Once there right click anywhere on the picture and click Set as Desktop Background from the pop up menu.
And there you have it. The image is now your new desktop background.
Option 2
1) Fistly locate the picture you want as your desktop background.slasher_x.gif
Then right click on the image and select Set as Desktop Background
Option 2 is a slightly quicker way of doing it as you don't really need to view the entire image in Windows Picture and Fax Viewer as long as you can see the thumbnail of it or you are in Filmstrip view.
To enable the thumbnail or filmstrip file view
In the picture folder click on the menu view and then click on the option Thumbnails or Filmstrip from the drop down menu. Or you can find the view icon on your tab menu.
NOTE: Just remember that if your image is in a 4:3 aspect ratio, such as 800x600, 1024x768, 1280x1024, it will be distorted and stretched if you are using as a background on a widescreen monitor.
Older 4:3 monitors (square monitors) use sqarish image resolutions such as 800x600, 1024x768 and 1280x1024.
Newer widescreen monitors use widescreen image resolutions such as 1152x864, 1600x900, 1680x1050 and 1920x1080.
on Nov 10, 2010 | Computers & Internet
Lcd monitor pink/green tint
Check the cable going into the back of your monitor and the cable from your monitor into your computer, one of them is most likely loose.
Dec 24, 2013 | HP Computers & Internet
Acer h233h monitor has blue tint all over screen
It's any one of these issues in decreasing importance video cable, video card, monitor. Make sure the video cable is plugged into the monitor and computer firmly first. After that, start replacing until you hit the culprit. You should be able to take any one of these items back to the store if it doesn't fix it.
Oct 22, 2012 | Acer H233H BMID 23 Widescreen HD Flat...
Moniter background is pink instead of white.
Hello gladyshbrown,
If the background is the only thing that is pink, then this will be as simple as changing your background color. the process is different depending on the operating system you are using, but if you right click on an empty space in your desktop chose either properties, or personalize. then choosing desktop.
If however this is not just affecting your background, meaning everything has a pink hue to it then it is most likely a hardware problem. To test this you can change to a different monitor, if the pink hue is gone then it is most definitely the monitor. However if the problem is the same on both monitors, then that would mean that your graphics card has gone bad. Many Pc's bought from dell, or hp have both video cards, and on board video. If this is the case with your Pc, you can move the monitor cable from where it is connected now, to the identical connection on the back of the computer. If you do switch to an on board video, please turn off your computer before plugging it in. This way when your computer is turned back on it will recognize that you are using a different video source. Most computers will do this automatically, however if it does not you will need to go into the "bios(cmos)" and enable onboard video. The option for bios is given as the computer first starts up. The key varies but it will be one of the following f1,f2,f10, or delete.
Aug 14, 2011 | Computers & Internet
My View Sonic VX2250-wm-LED monitor has suddenly gone pink. I work on a Mac Mini and the monitor has always looked beautiful. I just recently bought this brand new monitor within the last 4 months. ...
I would replace the cable that connects the monitor to the computer. If that doesn't fix the problem then return the product, it should still be under warranty.
Good Luck!
Feb 28, 2011 | ViewSonic Computers & Internet
I am running Red Hat Linux Enterprise my new Acer H233H is saying Input not supported any help would be greatly appreciated. Thank you
It says input not support because the PC video resolution is too high for the monitor to display, just need to lower the resolution. Nothing to do with OS, just the video setting.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.productwiki.com/acer-h233h/
If you set to native resolution and it still does not work then you will have to open it up and inspect the inside.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | Acer H233H bmid Monitor
My monitor has a yellow line running down the middle
This is a bad LCD panel. If it is still under warranty, your best bet is to have it replaced again. The only fix is to replace the actual panel and that would cost more than a new monitor.
Sep 28, 2009 | Acer H233H bmid Monitor
Recently, I purchased an Acer H233H LCD Monitor with the HP e9180f Desktop. However, the built-in stereo speakers in the monitor are not working. The sound card in the desktop is fine, as headphones and my...
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Jul 25, 2009 | Acer H233H bmid Monitor
Only get wallpaper background on my additional monitor
check the display settings of display card
Mar 23, 2009 | Computers & Internet
Acer H233H bmid Monitor Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
