Question about Philips Audio Players & Recorders
Philips amplifier type rh591 / 44z it is a
Philips amplifier type rh591 / 44z it is a entermant am,plifier with 4 channels pick, aux, tuner, tape
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: connecting amplifier
use pre amp with 10 inputs and connect its output to aux in----in mixer.
Posted on Jul 23, 2008
SOURCE: Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Posted on Aug 31, 2008
  • 17 Answers
SOURCE: Philips intergrated RDS Tuner FT980
mail me at siegfriedvik@gmail.com and i'll send you the repair manual;i also have one that has a similar problem and finally i found the manual
Posted on Jul 26, 2009
Turntable with built-in preamp won't play on phono channel on technics sadx950, but fine on CD channel. Is phono channel dead?
A turntable with a built-in preamp should not be connected to the phono input, because the preamp of the receiver or ampifier will be overdriven. The task of a preamp is to amplify the very low level of magnetic cartriges to the high level needed to work a line input and does some equalizing work to the signal. You can check if your turntable has a switch to disable the built in preamp (mostly they are low-end quality), otherwise connect the turntable to a high level input like "Tape", "AUX", "TUNER", "MONITOR", or "CD".
Nov 13, 2015 | Technics Audio Players & Recorders
How do i get a cd player to hook up to a sansui au 9900a amplifier as well as the sansui tu 9900 tuner
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
Sep 29, 2014 | Audio Players & Recorders
I have a technics SU-v500m2 amplifier connected via the aux input to my pc, i wish to link another amp to the same input, is this possible, and if so how?
Let's establish which is the IN and which is the OUT here. The PC is a Line Level source so its OUTPUT would feed one of the amp's Line Level INPUTs.
What's the second amp going to do in your scenario? Something other than the normal stereo channels; something multichannel (if your PC supports it); or just more speakers supported for the PC to feed?
An RCA Y-connector pair would share the stereo output of the PC with multiple Line Level destinations.
If a second amp with its own volume control is intended to share the same two channels with the SU-V500 it could also be slaved off the back of the SU-V500 wih an RCA patch pair exiting the Tape 1 or 2 REC(OUT) jacks. The second amp would receive full-volume audio from whatever source the SU-V500 is playing. Just don't activate the selected Tape monitor on the SU-V500 or you will cut off the source to both amps.
Sep 24, 2011 | Technics SUV500 2-Channel Amplifier
How do I connect my CD Player, Tape Deck and Tuner to the SU 300 Technics Amplifier
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
Jul 28, 2011 | NAD 218THX 2-Channel Amplifier
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
Hello i need help please..... I have a Technics SU-Z550 and SH-8055 Graphic Equalizer My amp has lost power... lots.! its working one channel louder than the other but the one which is louder still has...
If the same channel is dead on the EQ as is dead on the amp there may be a correlation.
Let's break this into its two parts.
1) SU-Z550: You don't say WHAT source(s) you tried to use on the CD/AUX, TUner and PHONO inputs. The external device itself could be the source of the low volume. Try swapping the Left and Right cables to see if it follows the source channel or stays with the amplifier channel.
Check the controls on the amp to make sure you understand each one's effect on the sound.
"PHONO" is literal and exclusively FOR A TURNTABLE - NOTHING ELSE - EVER.
2) SH-8055: Equalizers don't 'boost' sound, they modify its levels at various frequencies. To do that they should be connected into a Tape loop on your amp. OUTs go to IN's. Then you select the Tape Loop on the amp and that inserts the EQ into the signal path of whatever source you're listening to. It's actions are BEFORE any other amplifier controls such as volume, tone and balance. The EQ itself also has a Tape Loop to replace the one it occupies. Make sure it is not enabled unless you have a Tape Deck on it to use. Choose "SOURCE". The blue LED display is to show you frequencies are present in the program material.
Set all of its lighted band controls at midpoint prior to declaring it defective. EQ is like any spice - a little is good, a lot ruins the recipe.
Mar 21, 2011 | Technics Audio Players & Recorders
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
My Quote
Aug 30, 2008 | Audio Players & Recorders
Cannotsetorplaydvdorvcrtapes
Please recheck the model. It looks like it is the DVP33040V/17 model.
You said you cannot set or play DVD/VCR tapes.
1. Is this unit hooked up properly to your TV?
2. Is your TV set to its correct viewing channel?
This is the tunerless model so the very basic way of connecting this to the TV is using the composite cables (yellow/red/white). Then find the correct viewing channel on the TV. Note:IT IS NOT CHANNEL 3 OR 4. It depends on your TV make. Most of the time it is called AV, VIDEO, INPUT, SOURCE, EXT, AUX, GAME,etc. Most of the time, the TV remote control has a specific button with those labels. You can also check your TV manual how to get the VIDEO channel when using the composite cables.
Furthermore, if you would do recordings, you will need an extenal tuner (cable box or satellite box) for this unit. You have to connect an external tuner box using another set of composite AV cables - that is:
AV out from the cable/satellite box to VCR IN on the DVD/VCR.
May 18, 2008 | Televison & Video
Connecting amplifier
May 13, 2008 | Audio Players & Recorders
198 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
