Question about Canon imageCLASS MF8180C All-In-One Laser Printer
Setting Up Fax
Hi, Having trouble setting up fax... got any insturctions?
  • 2,039 Answers
Go to this link. Under Guides and Manuals, you will see a Quick Start Guide and a Facsimile Guide, in addtion to other manuals for the 8180c. Click on the link to open the guide in pdf format, click on the Save icon in the upper left corner to save it to your computer.
Posted on May 27, 2008
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
I am having trouble with setting up the fax function with my phone line. I have one line I am trying to use for both phone and fax. I am able to receive faxes automatically when I am not on the phone. ...
You need to make sure that the line from the wall jack is plugged into the "Line" jack on the fax then the phone is connected to the "Phone" or "Out" jack. You might want to check the number of rings before your fax picks up.
Oct 14, 2009 | Office Equipment & Supplies
Light fax
This could be a couple of different things. The first is that you are running out of ink or toner. Or you could have your toner save turned on. You can conserve toner using this feature.
When you set Toner Save to On, print
appears lighter. The default setting is Off.
1 Press Menu/Set, 1, 6, 1.
2 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
Jan 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Having trouble setting up my fax using HP Photosmart C2700 All-in-One Series. My fax number is the same as my home number. I can send a fax but cannot received one.
I've checked the user manual (if you don't have it, you can find it here) and you should take a look at chapter 10 - Fax setup, specially on Case E (pages 87-88).
Hope this will help.
Nov 28, 2008 | HP Office Equipment & Supplies
Having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Setup as fax
What you need to do to set up fax on most printers is use a standard phone cable. ( Cat 3 )
Plug one end intor the printer and the other end into a phone jack.
Then follow the instuctions on the manual to set up the fax number on the all in one printer.
With this printer you can also fax by using the microsoft software.
Here is the manual and it has step by step insturctions on how to set up faxing with software.
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
Nov 13, 2008 | Dell 924 All-in-One InkJet Printer
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Send Fax Issue
I have a brother intellifax 770 and I bought it used so their for I do not have the owners manual and I am having trouble setting it up and getting it to work. I can fax out but I just can't recieve faxes I can fax my daughter but when she faxes me she gets an error of 388 but she is able to fax and recieve faxes so we know her end is not the problem.
Aug 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Trouble
Set the reception mode to fax tad. (Telephone answering device). Lawrence
May 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Recieving faxes automatically
you have to set machine for fax mode by pressing auto answer button on key pad of machine. then you have received faxes automatically.
May 04, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
Canon imageCLASS  MF8180C All-In-One Laser Printer Logo
old marine
old marine
