Question about NetGear JGS516 16x1000 Mbps Networking Switch
Netgear Switch JGS516 internal PSU is faulty. Delta Electronics, INC Input: 100-240V -1.0A 50-60Hz Output: 5V ? 8A Model-ID: ADP-40VP Is there any chance to buy a new one in the UK Hope you can help
    Problem Solver:
  • 5 Answers
Fix the power supply... most likely the high voltage greenline power factor controller is out. about 10 dollars in parts will fix the power supply.
Posted on Nov 01, 2010
ASDA durabrand radio model no. LEDAB0701 information bar has stopped working
Hi - As per original question, NOT A TV, the LEDAB0701 is an ASDA Durabrand DAB Radio, so no remote! Just hit this problem - and found a work-around. Sound always worked - display and backlight failed. Could not spring radio apart - as well as the screw in the battery compartment - there seems an anchor the other end that defeated me. I run off the supplied Power supply and rechargeable batteries. The batteries ran down and I plugged the psu and display came back - for a few minutes! The sealed Power Supply unit (psu) is probably unregulated non-switched mode type. It gave 15.6v unloaded. Unregulated psu's normally run 1.4x nominal voltage with no load and are pulled down to the nominal voltage as the load current is taken (i.e. ASDA psu should have been 9v x1.4 =12.6v not 15.6v).
Seems the radio is sensitive to high psu voltage as when I ran off a regulated psu - problem partly went away. Regulated means you get whatever voltage you set whether no load, half load or full rated load.
Also once switched off fault appears the internal batteries were keeping the display off setting. I used a 12v 1A variable regulated psu. It has 9v, 6v, 5v settings. 5v is too low. 6v works when already running but it needs 9v to start. However the problem is that the display will still switch off if I run for a long time on 9v, so I have to switch down to 6v. Alternative, start on battery and plug in 6v works [6xAA=7.2v nominal, range: 8.5v down to 6v]. Seems some internal components of radio or psu have drifted/become faulty.
You need a positive center/hole polarity. Ideally aim at 500mA or greater replacement psu. Ideally use a variable one so it can be used for other things if your problem is different and this is not the solution. If you have an unregulated variable psu (400mA or greater) try running at 6v (will be higher but perhaps not too high) then switch to 4.5v or 5v (again will be 1.4x higher) but make sure it is set to positive centre/hole.
Apr 12, 2014 | Televison & Video
Where can I get information for Vector Product model Vec408
Try Googling (vector)(vec408)(manual) without parens.
Jul 29, 2012 | Camping, Backpacking & Hiking
Dead Netgear jgs516dead Netgear jgs516 . No lights. the inside power supply outputs 1.5V instead on 5v. Delta PS # ADP-40VP Where do I buy a replacement? I am in San Rafael, CA
Well, I believe the product you have carries life time warranty with NETGEAR. Hence, you can get it replaced from NETGEAR. Please log a support case with netgear at http://my.netgear.com
Regards
Anand Gupta
Apr 20, 2010 | SMC Netgear 16Port Gigabit Ethernet Switch...
Need the part number for the plug-in for the hp pavilion f1703
Assuming you mean the power adapter. Can't give you HP part number, but the one I've got is a Delta Electronics model ADP-50SH Rev. B, 100-240V 1500mA 50-60Hz input with 12V 4160mA output, positive center. Serial number is L6W0411009446. Hope that helps.
Sep 27, 2009 | HP Pavilion F1703 17" LCD Monitor
I HAVE 2 NETGEAR FS516 SWITCHES. BOTH NEED A NEW POWER SUPPLY.
Replace capacitor C3 47uf@25V. It will fix that ADP20KP 90% of the time.
Mar 05, 2009 | NetGear FS516 Networking Switch
Power supply for a 5500C
Delta Electronics
AC Adapter model ADP-36XB REV. B
Input:AC 100V-120V~850mA 50/60Hz
Output: 24V 1500mA LPS (Center positive)
Made in Thailand
Jul 02, 2008 | HP Scanjet 5500c Flatbed Scanner
Need to get a new charger
You could get a 120 watt (19v * 6.32A) universal laptop power supply on Ebay for £30. Ask the vendor to confirm that it is compaitible this laptop.
Dec 08, 2007 | Evesham Voyager 5700 Notebook
NetGear JGS516 16x1000 Mbps Networking Switch Logo
1,252 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
