Question about Lexmark Office Equipment & Supplies
My Lexmark 1200 do not print, I follow all the instruction and still don't print. I change both cartridge, they are new, desconect the printer, and still don't print, from the computer to the printer. I made a copy and no problem. I don't know to much about comp. but I have 1 year and 6 month using the printer and is the first time that I have this problem, no other person use the printer. I'll appreciate your help. My lenguage is spanish and sometime I can't understand what to do, so will you please try to explain the easier way that you can. Thanks, Mrs. Lesher.
    Genius:
  • 3,587 Answers
Hola...es necesario disconnect el computadore, desde el printer...
entonces, plug in el printer solo, sin connecion a el computadore.
empuje el power switch, y tambien, print una test pagina..
entonces, reporte aqui sus situaccion..por favor.
Posted on May 25, 2008
  • Patrick Michaels
    Patrick Michaels May 25, 2008
    now, why would you rate this inappropriate, when I used my broken spanish to assist you?
Wont print
It could be that your cartridges needs some cleaning. Try to follow the steps below to fix the problem:
  1. Make sure your printer is connected to your computer and is turned on.
  2. From your computer, go to Start menu.
  3. Go to Programs or All Programs.
  4. Go to Lexmark 1200 Series folder.
  5. Select Lexmark Solution Center.
  6. From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them from possible clogs and dirt. After successfully printing the page, try to print your document again to verify that the problem is fixed.
If that doesn't help, you can manually wipe the cartridge nozzles with a slightly damped paper towel. Then reinsert the cartridges and try to print again.
If the problem continues, then it could be a faulty cartridge. Try to insert a different known working cartridge or better yet a brand new genuine Lexmark cartridge. Lexmark products work best with original supplies.
I hope this helps. Thanks.
Nov 19, 2011 | Lexmark X1240 All-In-One InkJet Printer
Have color cartridge in, bottom tab removed and printer will not print in color
Print quality issues could be due to clogged cartridge nozzles. Please follow the steps below to clean the print cartridge nozzles:
  1. On your computer, go to Start > All Programs / Programs > Lexmark 1200 Series > Lexmark Solution Center.
  2. From the Maintenance tab, select Clean to fix horizontal streaks.
  3. Your printer will then print a clean test page forcing ink through the cartridge nozzles and clean them.
  4. Try to print again.
Jul 24, 2011 | Lexmark X1270 All-In-One InkJet Printer
Used x4270 .no cd to download. list of printers does not inclued 4270. having problems with error 1200. took out old cartlidge and don't know how to put them back. have printer connected to computer...
Try to fix the 1200 error first. The error indicates that the cartridge carrier has stalled. Please refer to this article to fix the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One. Once your cartridge carrier is functioning properl, re-insert your cartridges - How to Install Ink Cartridges In Lexmark X4200 Series AIO.
You can download the Lexmark X4270 driver by visiting the Lexmark website at http://bit.ly/gKXn7F. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
For your scanning concern, especially when scanning documents, you will need the Lexmark OCR scan software to do the job. The scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X4270 All-In-One InkJet Printer
Aligned correctly at first. now is saying error #1200. Will not print in black. Its a new cartridge.
Hello. Error 1200 is caused by the carrier getting stalled. Here's an article in the Lexmark website to give you some instructions on how to remedy the problem. Just click on this link: http://bit.ly/aCuDKk . Just follow the procedures carefully. Good luck!
Mar 19, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Lexmark z2300 eplacing ink cartridges
Go to www.lexmarkz2300.com. There will be instruction on how to replace the cartidges. you will b e able to print out the instructions after you fix the problem.
May 21, 2009 | Lexmark Z2300 InkJet Printer
Changed ink cartridges cannot print alignment page, out of ink
You need to reset the ink level before the printer can print further, to do these please follow the following step:
Then try again with printing alignment task.
Hope this help.
YBC (/\)
Feb 26, 2009 | Lexmark X2500 All-In-One Printer
Hope this help.
YBC (/\)
Feb 18, 2009 | Lexmark X2500 All-In-One Printer
Lexmark 1200 series printer won't print
Call me and I can walk you through what Lexmark just walked me through with the same problem
Laurie
732-356-7256
Jan 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
PRINTER
The following link provides the user guide and setup sheet for your printer. They explain how to change the ink cartridges.
http://www.lexmark.com/publications/eng/1200/index.html
Dec 25, 2007 | Lexmark X1270 All-In-One InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
