Question about Scosche Industries Scosche Gm1598b Iso Din with Pocket or Double Din Installation Kit (For 2006 Up Chevy ImpalaTah
My remote start and locks have poor range what is a good fix for this problem
  • 4 Answers
Make sure the remote battery has good voltage. If the remote start has a single wire for the antenna, make sure it's as straight as possible. Your better systems have a black plastic antenna that is placed high on the windshield.
Posted on Sep 29, 2010
I have a compustar from-2w9000-ss remote and a button was pressed,locked me out ,what buttons do I press to get it to work again
PRIME 9000 1-Mile Range, 2-Way Select - Compustar
www.compustar.com/product/prime-9000/
Compustar1-Mile Range, 2-Way Model: RF-2W9000-SS ... The classic Compustar look that made us the top remote start brand in North America. ... The screen keeps you updated on whether your doors are locked and in the event of an alarm trigger, the ...
Compustar RF-2W9000-SS remote kit failure? - 8th Generation Honda ...
www.8thcivic.com > ... > ICE, Electrical, Security, & Navigation
Jan 8, 2015 - 4 posts
I have had my Compustar RF-2W9000-SS remote kit and secondary remote ... on my 2008 Honda Civic SI Coupe, FG2, at a compustar authorized dealer. ... my remote was not responding to my car (the unlock/lock, autostart, ...
CompuSTAR Starters - TheCarSalon.com
www.thecarsalon.com/home/automotive/remote-starters/compustar/
Either tap buttons I and III or Lock and Trunk simultaneously on your remote. ... The introduction of the RF-2W9000-SS in 2010 ushered in a new generation of .
RF-2W9000-SS by Compustar from Remotely Started MN
remotelystartedmn.com/product-details.php?product-id=40
Jan 07, 2016 | Cars & Trucks
My range alarm keeps going off on my sony baby monitor when still in range. how do i fix this?
I took the battery pack out and just used it plugged in. The only problem is the voice activation setting doesn't work. Not sure why it would work on the other setting and not this one? It did quit beeping and crackling though.
Apr 27, 2011 | Sony 900mhz Baby Monitor
The remote start works (starts the vehicle) only when the fob is very near (inside) the controller.
First check the battery voltage. A good new battery will be about 3 volts. If it is significantly less, get a new battery and retry. Examine the battery contacts since you have the remote apart to ensure that they are clean and shiny. If they are dull, use a pencil eraser to clean the contacts. If you are still getting poor range you can try to reprogram the remotes to the OEM keyless entry system. The procedure follows.
Transmitter Code Programming
Note: The receiver (ETACS module) can save maximum two codes from the transmitter.
1. Apply the battery voltage to the terminal "6" of DLC (Data Link Connector),{see attached image}. The DLC is located on the left side rear of the engine compartment. The wire color for terminal #6 is red/black.
2. Turn the ignition switch to "ON" position.
3. While coding one transmitter.
Press the lock button of transmitter for 3 seconds over until the turn signal lamp turns off.
4. While coding two transmitters.
Press the lock button of one for 1 second while the turn signal lamp turns on, and then press the lock button of the other for 1 second over until the turn signal lamp turns off.
5. Remove the battery voltage, and then the transmitter code is re-saved on the receiver.
6. Check the operation of the keyless entry system.
If you still experience poor range, you may need the system serviced or the remote replaced.
Nov 09, 2010 | AutoCommand Remote Car Starter Add-On
We have poor range on opener button
Check to make sure your batteries are good. If you have short range on more than one remote you can check this out.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Would you recomend the Audiovox Prestige APS901N for my '06 Chrysler T & C mini van?
IF RANGE IS NOT IMPORTANT I SUGGEST A AUDIOVOX AS9076N . ITS AN ADD ON REMOTE START WHERE YOU WOULD PRESS
LOCK
THEN UNLOCK
THEN LOCK AGAIN ON YOUR FACTORY REMOTE AND THIS WOULD START THE CAR.
I BELIEVE THE IGNITION KEY HAS BUILT IN KEYLESS ENTRY BUTTON ON IT ALREADY. SO WHY CARRY ANOTHER REMOTE?
MOST OF AUDIOVOX MIDRANGE SYSTEMS HAVE THIS OPTION FOR ADD ON REMOTE START SYSTEMS WHERE YOU CAN USE THERE REMOTE OR TIE IT IN WITH YOUR EXSISTING REMOTE.
OTHER UNITS WILL HAVE DOUBLE LOCK OPTION TO START CAR. OR TRIPLE LOCK OPERATION.
Dec 24, 2009 | Prestige Remote Start
Alarm remote is not communicating with car
These units are troublesome...you'll have to take it to a car stereo shop that does alarm installations and have it diagnosed or replaced...Don't buy another Scosche.
Good Luck
Jun 21, 2009 | Scosche Rsa1400A 1-Way Am Alarm & Remote...
Driver door lock not opening with remote
your door lock actuator is worn out or loose wire or poor contact.
May 03, 2009 | 2007 BMW 525xi Sedan
2006 Chevy Impala Remote Start Poor Range
Yes some do some don't, my 2005 Dodge 200-400 feet, my 1996 Corvette 20 feet, my wife's 1998 Buick about 50 feet, is the remote battery ok? should be changed at least once a year
Dec 03, 2008 | 2008 Chevrolet Impala
Remotes have poor range
Here is some information that may help you.
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range doesn not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
Jan 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Scosche Industries Scosche Gm1598b Iso Din with Pocket or Double Din Installation Kit (For 2006  Up Chevy ImpalaTah Logo
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
