Question about GPS
Not locking onto satelites
Will not lock onto sattelites
  • bubba35 May 30, 2008
    I have the garmin etrex vista hcx. The power comes on but I don't lock onto satelites. My previous waypoints are still there but a question mark blinks on the black triangle. new batteries. ???????????
  • kbarr70 Jul 23, 2008
    My I.trek will communicate with my phone but refuses to lock on to any satelites. Actually the "yellow light" that is supposed to indicate that the unit is searching for satelites does not even come on.
Throw skycaddie away, The support has been ugly, so ugly that I could care less about the 300 bucks....at the trade the guys promised everything..then called em afterwards, poof..very different guys..........................bye skycaddie
Posted on Aug 24, 2008
I have a garmin 660 ,cannot get sattelites
Posted on May 26, 2008
Cursor on my toshiba sattelite is locked
Hi
This is not automatic lock but you have turned off the trackpad
Hold the Fn key and press F9 key this will re-activate the mouse and then you can use it.
It is provided to turn off because then you type if your palm touch the trackpad the cursor will move and you may start typing somewhere else.
DO RATE MY SOLUTION.
Jun 29, 2011 | Toshiba Sattelite A105-S2051 Notebook
My gps freezes when locked on third sattelite
Hi! these occurs mainly due to detail value(s) input and map redrawing directions apart from memory levels.
Dec 21, 2009 | Garmin GPSMAP 76 GPS Receiver
I have a HK 595 sub. with no sattelite cables.
you need the the satellite speakers hooked up in order for the sub to work. its not a standalone sub the volume control knob on the satellite speaker is what powers on the sub. i have extra speakers i wish i could give you cuz my sub just blew out.
Dec 20, 2009 | Harman Kardon HK595 Computer Speakers
Magellan 3200 freeze
there is a little square at the top right corner of the screen. when you first turn it on, press that square to see the satelites it has locked on to, once a few of those turn green (meaning you are locked on by sattelites) see if the map starts workign again. Mine did the same thing and i thought is was broken, but depending on where you are, it can take up to 10 minutes for the map to start working (as it need that astelites to tell it where it is and what is around it) get it? so just try waiting before you put in a destination.
Aug 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
MY H2OC LOWRANCE HAND HELD GPS IS LOCKED ON MY LAST POSITION
check the BAUD rate is correct as in the manual
Jul 20, 2009 | GPS
Unable to aquire satelites garmin nuvi 255 w. flew from newfoundland to toronto. unable to aquire sattelites at toronto.
When you change geographical locations with any GPS it will take a lot longer for the GPS to acquire the sattelites. Hold the GPS out in an unobstructed area and switch it on. Be patient it will acqurie the signals if it was working before you left home.
Apr 01, 2009 | GPS
Nuvi 350 finds satellites but won't lock on
Please read this solution, which might help you. On the Nuvi 350, press and hold the lower left corner while turning on.
http://www.fixya.com/support/t1155473-garmin_nuvi_660_not_locate_sattelites
- Jim
Nov 22, 2008 | Garmin Nuvi 350 Car GPS Receiver
I have a garmin GPS map 162 and during operation the screen goes blank except for a vertical line.None of the controls allow me to shut down, I must disconnect the power. I called Garmin and they sent a...
The problem is the government made changes to the WAAS satelites. When the GPS tries to find the sattelites, it can't lock on and goes into an error mode and locks up.To eliminate the problem disable the WAAS which can be done when starting the unit. Then go online and download the 3.70 firmware version and load it into your unit. This will correct the system to function with the newer WAAS system. After installing the 3.70 software then you can enable the WAAS function.
Good Luck
Richard
Sep 06, 2008 | Garmin GPS
Can't lock onto satelite signal!!
Sounds like the aerial. There is a very fine wire in the center of the male aerial plug. If this is bent then you will have that problem. Aerials are hard to get, dealers say they are obsolete...update your model. Cheers, Peter
Feb 27, 2008 | Lowrance Globalnav 310 GPS Receiver
GPS Logo
188 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
