Question about Microsoft MS-DOS 6.2 Step-up Files
What is the latest MS DOS version. is DOS 6 still good as promise?
    Brigadier General:
  • 10,406 Answers
Yes, MS DOS will still work on "new" motherboards & new CPUs, but *WHY* would you want to use it?
Posted on Sep 29, 2010
Msi ms-7142 driver
You can get all the drivers for the MS-7142 motherboard (also known as the k8mm-V) at:
http://www.msi.com/product/mb/K8MM-V.html#/?div=BIOS
If you've installed the latest drivers, which is what they'll tell you to do at MSI, and your problem persists, which it may, I'd try installing the version just prior to the latest. Even professionals make mistakes and sometimes a problem with a latest version may not exist if you backtrack one release revision.
Good luck with the install! William
Feb 28, 2011 | Dryers
Hard drive not found missing keeps flashing up
1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME
Jan 31, 2011 | Sony XP Pro Upgrade - VS-E85-00087 Upgrade...
What are the different parts of MS POWERPOINT?
http://office.microsoft.com/en-us/powerpoint/powerpoint-2010-features-and-benefits-HA101809930.aspx Visit this page and you will get an overview about MS PowerPoint from it's manufacturers.
Best Regards NextDoorNerd
Jul 28, 2010 | Microsoft PowerPoint for PC
Have Dell D266x gives me dell page that says bios revision and wont kick into windows
Visit the Dell Drivers Downloads websites and download the lastest BIOS version for the notebook.
See if you can get an MS-DOS version. Boot the system using an MS-DOS repair disk. then attach the disk with the BIOS setup by USB.
If you don't see an MS-DOS version, you may have to format and install or do a fresh install of your operating system (or a lower version that supported the BIOS). As soon as windows is re-installed, run the windows version you downloaded from the source disk you saved it.
This should work!
Apr 03, 2010 | Dell Latitude CPI-D Notebook
Registration codes for viking softwares
PC analyzer for MS DOS. You get a registration key to unlock the shareware version.. Free download of Dr. Hardware Sysinfo (MS Dos) Key/RegistrierschlRssel 8.0, size 0 b.
Oct 05, 2009 | Nokia 6600
Transfering of files.
Maybe its your windows system, Try Vista or updated version of XP if thats what you have.
As far as i know MS-DOS is a thing on 98!
Aug 25, 2008 | Sony Ericsson Walkman® W880i Cellular...
Unable to load
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Dec 06, 2007 | Microsoft Windows XP Home Edition
Dfe-520tx/rtl8139 novell netwrking 4.2 drivers (dos6.22)
This device does not support anything older than Windows 95, DOS 6.x predates that quite a bit. There simply is no support for USB in DOS, sorry for the bad news but as an alternative you can probably pick up some older ISA buss cards (or PCI if you motherboards support them) that do support MS DOS 6.x. If you can't find them locally EBay probably has some. Let us know if we can answer any more questions and please don't forget to rate the posting.
Jan 06, 2007 | D-Link Network Cards: DUB-E100 USB 2.0...
Computers & Internet Logo
61 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
