Question about Whirlpool Refrigerators
Whirlpool side by side fridge/freezer model S20BRSB21-A/G - no signal on L2 of compressor relay - display stuck -21 & +4 respectively - could it b main pcb?
  • 2,382 Answers
Hi, if the display is actually stuck on -21 & +4 respectively without it changing and there is also no signal on L2 of compressor relay then your thoughts about the main pcb is right.
Posted on Sep 29, 2010
Why is my Whirlpool s20brsb21 fridge not staying cold ,the temperature seems to vary and food is going off
The most likely fault is the relay on the rear board located behind the back panel , take out the plastic housing that contains the printed circuit board and take the lid off then switch the fridge on and listen for the compressor starting if after 15 minutes it does not start tap the big orange relay with a the handle of a screwdriver if the compressor starts you need to change the relay and associated capacitors, if that is not possible just change the complete board.
there are loads of other possibilities but that is the most likley
Aug 01, 2014 | Whirlpool Refrigerators
Why do freezer coils ice up on my Stainless Steel Whirlpool refrigerator (model GB2SHDXTS)?
On your model your cntrl board has a relay that can stick causing the compressor to always run even when the unit is turned off or in defrost. turn the fridge off, move the temp of the freezer to it's warmest setting and it should display a line in the freezer and fridge temp display. listen to hear if the compressor is running in back of the unit. if it is you need part number: 12868513
Mar 15, 2013 | Whirlpool Refrigerators
Fridge makes clicking sound every 60-90 seconds..freezer defrosting, fridge not staying cold.
If the clicking sound you are hearing is from the back of the refrigerator near the floor then I believe the sound is coming from the start relay that is located on the side of the compressor.
Replace the start relay with a new one and you should be good to go unless the compressor has been damaged.
The start relay is easy to replace as it just plugs into the side of the compressor. Start relays are also often very inexpensive.
Make sure to use your model number and get the factory direct replacement start relay and not a 3n1 universal start relay.
Aug 07, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Model # (P) 55662 serial # (S) 10149733GT Freezer is at 41' and fridge is at 49' and both are climbing. they were at 38' & 48' respectively this morning. * hours ago we tried: ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Kenmore Side by Side Refrigerator
Side by side , fridge & freezer both stopped cooling last night, cleaned every thing this morning, unplugged for about 2 hours, plugged in and can hear fan running, but fridge and freezer do not seem...
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Jan 09, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
I have lights and power but no cooling in the fridge or freezer
The themostat could be stuck open, the defrost timer could be stuck in defrost or the compressor start relay/overload could be bad. All are worth fixing.
Bump the thermostat with the heal of your hand. If the fridge starts, the termostat is bad. The defrost timer is in the same housing as the thermostat. There is a dime sized hole in the bottom of the housing that will show a white or black "screw". Use a screwdriver to turn it 1/4 turn. If the fridge starts, timer is bad. You need a tech for the relay/overload.
Mar 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Heard a "buzzing" noise and then smoke appeared, smelling like burning plastic. Now the freezer and fridge are not cooling. When I open the freezer side there is a fan that is still running.
you need to oder whats called an overload and relay
its a whirlpool so www3.sears.com would be the most help
type in your model
do the search in the compressor area
usually part number 4 but no guarentee
OVERLOAD and RELAY
might be one part or two dependiong on your modle
have a great day
Oct 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool fridge not cooling gone warm air blowing
more than likely the compressor is not starting, it has a starting device on the left side of the compressor which has a relay/overload called a relay, remove the relay and shake it , if it rattles it has gone bad. the relay/overload combination has gone bad and can be replaced with pro41 relay. if the compressor has a run capacitor just eliminate the capacitor when replacing with new relay. connection of the two wires makes no difference.
Jan 16, 2009 | Whirlpool GS6NBEXR Side by Side...
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
Nov 09, 2007 | Whirlpool ED5FTGX Side by Side...
Refrigerators Logo
101 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
