Question about Toshiba E-Studio 3511 Color Copier
Error code cf30 in toshiba 3511 what its mean and how can fix it
Cf 30 1 kopy cf30 error toshiba 3511
Posted on May 05, 2012
    Sniper:
  • 66 Answers
(CF30) - Reference plate detection voltage abnormality: The output
value of the color auto-toner sensor against the reference plate
is out of a specified range at the light amount correction during
an auto-toner adjustment or when a print job has finished.
Your color auto-toner sensor and reference plate are located under the input tray cover on the left side of the copier when you are facing it. It is on a bracket that hangs down into the copier and sits close to the revolver inside the machine. It is an optical sensor and if either it or the reference plate get stained with toner it will give you this error message, you may attempt to clean them with rubbing alcohol.
This error message may also occur if the solenoid that drives the reference plate is faulty so you will need to check that as well.
I would sincerely recommend that you get an authorized toshiba technician to take a look at the machine for you as this is a fairly difficult problem to fix right.
Posted on Sep 29, 2010
  • albanmeni
    albanmeni Apr 16, 2012
    I got an authorized toshiba technician and he said me that this problem is occurred from LG board. Is this possible?
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
MY TOSHIBA E STUDIO 451c HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
That code error meaning that you have a problem with HHD
1st you reboot your machine with push 0+8 than 690 start 2 set(interrupt).
If it don't wok you mast replace your HHD with a new one from Toshiba.
Aug 11, 2012 | Toshiba E-Studio 3511 Color Copier
Toshiba e studio 3511 F120 error need to know what this error is and how to fix?
F120] Database abnormality
(1) Rebuild the databases. (Perform 08-684.)(2) If the error is not recovered, initialize the HDD. (Key in "2" at 08-690.)
Any money the HDD is duff. Srri
Apr 28, 2011 | Toshiba E-Studio 3511 Color Copier
Ca 20 error on toshiba 3511 copier
CA20 indicates H-Sync detection error.
U need to check whether the cable (flexible flat type) between the connector (CN334) on the LGC board and connector (CN201)
on the LDR board open circuited, broken or disconnected. Try to replace another cable.
Jan 05, 2010 | Toshiba E-Studio 3511 Color Copier
F 105
How do u get in service mode on a toshiba 3511
Nov 06, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
MY TOSHIBA E STUDIO 4511 HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
format hard by power on+0+8 then 690 then start then2 then set then report the mashin or revision the logic may be there is a problem in it
Sep 21, 2009 | Toshiba E-Studio 3511 Color Copier
My Toshiba e-studio 3511 gives me a C010 error, what does that mean??
C010 indicates main motor abnormality.
U need to perform output check 03-101(ON)/151(OFF) to off the main motor. If main motor not running under output test, probably u need to replace it.
If motor working, u might need change the LGC board.
Jun 24, 2009 | Toshiba E-Studio 3511 Color Copier
I have a copier, printer, fax, scanner Toshiba e-Studio 3511 that shows error code CE50. Anyone can tell me what that means?
That is a auto toner sensor error code. Your machine most likely needs to be cleaned. That machine model will only cause you problems if all of the machine modifications are not done. You will need to take the left side cover off and completely clean inside the machine. Well worth the money to get a technician out to fix. Your machine will need to be re-calibrated.
Jan 20, 2009 | Office Equipment & Supplies
Toshiba E-Studio 3511 Color Copier Logo
1,081 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
