Question about Kenwood KRF-V5100D
Hi, I have a Kenwood KRF-V5100D. when I turn the volume up the numbers in the display go down and vise versa, it also doesn't keep the setting I put in it. Both are not stopping it from working but are really really annoying. is the a way to fix this? I have tried reseting it and this doesn't help. thank you
informatica
  • 1114 Answers
SOURCE: Operating Manual
Hi - You can download the manual from the link underlined in blue below:
KRF-V5060D
Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Jul 26, 2008
mebeog
  • 8 Answers
SOURCE: my kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Posted on Dec 04, 2008
  • 4234 Answers
SOURCE: my kenwood krf-v4060d reciever on/off switch is faulty.
The problem is not likely to be the switch itself. The unit is rpobably going into "protect" mode because of a problem internally. Try removing all the cables and try to turn on the unit. If the behavior remains the same, the output section requires repair. The most common failure is the output transistors. Expect a parts cost in the $40-$60 range.
Dan
Posted on Dec 09, 2009
caroldon
  • 17130 Answers
SOURCE: kenwood krf-v4060d receiver display problem,
it is possible that the voltage to the filament of the display is absent. This is normally a 3.6 volt AC which comes from the transformer and it can be lost a the connectors or the circuit board. It will be best to use a multimeter to trace the voltage to the display unit. check the voltage to the display driver IC, check the negative grid voltage to the display , if there is an open resisitor of the feed to the display voltage to the IC. Finally check the continuity of the filament of the display unit.
The driver IC is also a suspect , sumulate heat and see if the fault comes up easily which can confirm the case.
Posted on Sep 05, 2011
  • 4234 Answers
SOURCE: My kenwood krf-v5300d overloaded? Stand by light
This unit is in what is called "protect" mode/ See the link below for an explanation of this. Specifically to your unit, the output components are unique to Kenwood and are not cheap. Further investigation to locate the reason for the protect mode will be necessary prior to any attempt to estimate the cost of repair. Something as simple as a missign voltage can cause this symptom.
Please feel free to update this with any other questions or concerns that you may have.
Dan
Link: http://www1.fixya.com/support/r5390728-protector_means
Posted on Oct 21, 2011
What would be wrong with my kenwood-krf-v5100d and the front right and left speaker out lets are not working propaly sound dose come out of them but it is real low and when you go to turn them up inde
There is a balance option. Find the manual for this player and look for balance. You are looking to change it to 0 so that it plays through all of your speakers at equL volumes
Jul 24, 2014 | Kenwood KRC-379R Cassette Player
Centre channel pops
Popping is usually a sign that the output transistor on the amp (center channel) has blown - quite expensive to repair. eBay is good for picking up cheap but fully working receivers
Jan 16, 2014 | Kenwood KRF-V5100D
How do I hook up a pioneer dynamic expander ex9000 to a kenwood KRF-V7030D receiver?
• Pioneer EX9000 out to Kenwood V7030D play In
• Pioneer EX9000 in to Kenwood V7030D rec Out
• instruction on page 8 of the manual
PDF] KRF-V7030D KRF-V6030D KRF-V5030D KRF-V4530D
Jul 31, 2012 | Audio Players & Recorders
Hey,i have a problem with krf5100,when i do speaker custom setup,my RB and LB wont work,they even dont appear to display like L and R .whats the problem?
First of all, the KRF-V510 doesn't support direct powering of the Surround back but it does have a Pre Out to drive externally amplifed Surround back speaker(s).
The indicator for BS on the front panel is NOT an indication of speaker presence. It IS an indication of the INPUT presence of that channel.
During setup you will only see RB or LB ...
Page 17: IF you have something other than OFF set for Surrounds....
Page 17, step 9: AND you select something other than OFF if you have Surround back Speakers attached to the speaker connectors...
.. and complete the rest of the setup properly. You should HEAR the Test Tones on all speakers. If the Surround Back is inaudible you would need to investigate the external amp/speaker combination you're using.
http://images.kenwood.eu/files/images/products/product_id_229/file_category_26/KRF-V5100D_V6100D_ENG.pdf
Jan 02, 2011 | Kenwood KRF-V5100D
My kenwood is only playing sound from the front 2 speakers the center and surround is not working. is there a fuse inside i can change? what do i need to do?
Not a fuse. Go through all the setups and speaker definitions or maybe just find that pesky "stereo" mode switch and reset it to something that allows all the channels to operate.
Jan 22, 2010 | Kenwood KRF-V5100D
Kenwood krf-x9995d surround issue
It's likely the power amp is faulty. However if you can't get in touch with Kenwood, then take it to another repair shop or go back to the other and tell them you can't get in touch with Kenwood and could they have a look at it anyway.
May 27, 2017 | Kenwood Audio Players & Recorders
I can only get 2 speakers to work - the L and R speakers - I don't know how to tune in the central and other 2 speakers :-) I don't have the instruction manual
http://www.kenwood.eu/products/home/separates/avcc/KRF-V5100D/
goto the above link and follow the steps for setup,test and use as shown on the instructions, after checking all the connections for the speakers.
I used to set up home theater kits for a living and often found that a wire or two was clipped in on the insulation rather than the wire.
May 17, 2009 | Audio Players & Recorders
Operating Manual
KRF-V5060D
Jul 26, 2008 | Kenwood KRF-V5060D Receiver
Kenwood KRF-V5100D Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
