Question about Caple Ovens
Caple cooker cr9210 large oven lights but will not go onto full burner. i have fitted a new thermacouple
2 Suggested Answers
  • 417 Answers
SOURCE: belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Posted on Dec 22, 2009
Testimonial: "thanks ashburton i will attempt to change the element first."
Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Oct 01, 2016 | New World Ovens
Tip
Caple Oven not heating? How to replace a Caple fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
on Jan 30, 2014 | Caple Ovens
Two large cookers light up but as soon as the knob is released they stop burning
bad igniter switch aka the knob ur pushing is bad can check with a multi meter for continuity
Mar 07, 2015 | Ovens
Caple C3242SS Double Oven. Fan rattling in Main Oven when turned off after cooking on manual.
Since it is new contact the people that sold you the oven for warrenty repair.
Nov 18, 2014 | Caple Ovens
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
I have an older (1997) GE XL144 Gas oven. The burners light but the oven won't heat. Any suggestions?
IF THE PILOT LIGHT IS LIT BUT THE BURNERS DONT FIRE IT IS PROBABLY THE THERMOSTAT. FREEZE A LARGE OVEN PROOF BOWL FULL OF WATER PLACE IT IN THE OVEN FOR TEN MINS TO COOL THE OVEN TO BELOW ROOM TEMP AND THEN TRY THE OVEN IF IT WORKS FOR A SHORT TIME THEN STOPS CHANGE THE THERMOSTAT
Oct 01, 2010 | GE JGRP17 Gas Single Oven
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
How do I change the fan oven thermostat on cooker Tricity Bendix SIE 531 TCGR
These will give you the basics
1 How to change a fan oven element and How to change a cooker oven fan Motor
2 How to fit a New Thermostat to a Cooker or Oven
If you have a electric Cooker or Fan Oven which is not heating it could be one of the following problems.
3. If you have the opposite problem i.e. your oven is over heating and burning everything then you will need to replace your oven
thermostat
Mar 04, 2010 | Ovens
Oven won't light - electronic ignition oven
Hi, it could be your, electric heating element and oven burner gas valve. both are located in oven burner compartment, remove last bottom panel, locate oven burner, the valve that feed gas to burner, has two wires connected to it, that's oven valve could be faulty, also look on side oven burner, you will see electrical heating element, could also be faulty, it's better to replace both oven valve and element, that's the most common problem, but first check oven thermostat, that's knob you turn to light oven, if thermostat o/k, then it's your oven valve or heating element, (used to ignite oven burner) or call a mechanic, good luck.
Aug 12, 2009 | Kenmore 33169 Gas Single Oven
Ovens Logo
26 people viewed this question
Top Caple Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Caple Oven Expert? Answer questions, earn points and help others
