Question about Belkin (F5D7231-4) Wireless Router
I want tp put a password on but..had the riuter ages..but dnt no how to put a password on
  • 708 Answers
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Posted on Sep 29, 2010
Login Page Error
reset you router, put the default id and password, the address to put in your bowser is http://tplinklogin.net/
Mar 14, 2014 | TP-LINK Computers & Internet
I have a panasonic home theater system and am trying to hook it up tp my technics reciever and its not working how do i do it
EVERY TIME I TUEN ON MY RECEIVER IT STAYS IN THE STANBY LIGHT AND IT DNT ALLOW ME TO LISTEN TO MUSIC
Oct 03, 2013 | Technics SA-AX730 Receiver
Ruter tp-link efb6f6 pin
Hello the homepage is here:
http://www.tp-link.com/dk/support/download/?all=1
Search for the manual by model number.
http://www.tp-link.com/en/article/?faqid=92
Type the username and password in the login window (the default username and password are both admin), then click OK.
More here:
http://www.tp-link.com/en/article/?id=85
Good luck
Nov 22, 2012 | Computers & Internet
I have a new kindle but I cannot set it to work on my TP-Link Modem as I don`t know the password to put on the Kindle, I would like to buy books but until I get connected I carn`t do a thing, I can ge
What you need is the tp-link encryption key password
Hopefully it is displayed on the bottom of your tp link modem otherwise you will have to log into the modem from a computer and find out what the wi fi encryption key is.
Hopefully the admin user name and password is displayed on the modems case ?
otherwise open a browser on a wi fi - working pc on your network
typw in 192.168.1.1
TYpe in admin for user name
admin for password
hopefully the modem is still set on default name and password and has not been changed
Then look up wi fi settings
Wi fi security settings to find encryption key nad method used WPA or WEP ?
Jul 23, 2017 | Computers & Internet
Have a GE GG40T6A gas hot water tank. Leaking really bad out of the pressure relief valve. It is a rental property, gas was off to the house (tenants moved out in the night). When the gas company turned...
12 year old water heater is getting near the end.
Some tanks last 20 years, but that's the exception.
To find exact age of your brand water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
Leaking TP valve:
1) Lift TP lever and gently lower back into position to see if that stops leak.
Occasionally something gets stuck in the valve.
2) Sometimes water heater temperature gets turned up because heater is not producing as much hot water as before, and higher temps cause TP to release pressure because of overheating.
Dial temperature down to 120 degrees.
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
3) If steps above don't fix problem, replace TP valve >> TP valves have 125 or 150 degrees rating >>> older tank shouldn't be running above 125 because higher temps cause more pressure on tank, so thermostat should be lower than 125 degrees TP rating.
Buy replacement TP at any hardware store + a roll of teflon tape to seal pipe threads.
Turn gas control to pilot ... this will keep pilot lit but burner will not fire.
Let water cool, and then drain some water out of tank.
If TP valve is on side of tank, then open drain on side of tank and drain water until it is lower than valve level. Open bathtub spigot to let air into line.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Be careful around water that is higher than 120 degrees F >> you can get burned quickly >> apply cold water to any burn.
Use pipe wrench and unscrew TP valve counterclock-wise.
Install new TP and put teflon tape on threads.
Re-fill tank completely and open tub valve on hot side until water is running >> then turn gas control back to original position.
Do not fire up any water heater before tank is completely full of water or this could damage tank.
To read more preventative information about water heater leaks and age problems:
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Nov 24, 2010 | General Electric GE SmartWater Household...
Hi, I have forgotten the password for my Wi-Fi riuter F5D7230-4. How could I find the password, log on and change some settings? Best regards, Georgi
>Hi, open up a browser and go to 192.168.2.1 (this is your router's GUI).
>On this page you can configure your security settings.
Sep 30, 2010 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
I forgot my password for samsung behold
contact customer care and they should be able to supply you with a code to unlock your password
PLZ RATE THIS IF YOU FIND IT HELPED YOU IN ANY WAY TANKS.
Jul 20, 2009 | Samsung SGH-e315
Lost my password!! how do i recover it or reset it.
There are several tools available for resetting a Windows password. I personally use a Linux tool, but there are some alternatives.
http://pcsupport.about.com/od/toolsofthetrade/tp/passrecovery.htm
At this site they list 5 common programs that will allow you to reset your password. Let me know if you need any more help with them :)
Apr 16, 2009 | Computers & Internet
Belkin (F5D7231-4) Wireless Router Logo
22 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
