Question about Maytag MAH6700AWW Neptune Front-Load Washer
"do" code and "fl" code appear and washer door is stuck
Same as subject, looking for the solution.
  • 868 Answers
Replace the wax motor /Door latch
Posted on May 25, 2008
Maytag Neptune code fl shows on display
The FL code indicates that the door failed to lock when you closed it. Try opening and closing the washer door again. Make sure that there is nothing in the door area that could block the latch or keep the door ajar. If the error recurs, the latch may be faulty.
If the door is actually locked and giving the FL code, the latch has a problem. You can try power-cycling the washer (unplug for a while) or setting the washer to pump the water out. If these steps don't help, you need to order a replacement latch assembly. Depending on your washer model, you may have a manual pull cord to unlock the door. Look under the bleach and fabric softener compartments after opening the dispenser..
I hope this helps. If your washer is under warranty, contact Maytag. Otherwise post a comment with the model number of your machine for a source for a replacement latch assembly.
Oct 27, 2014 | Washing Machines
FL code on Washer
FL is a door lock code. open the soap dispenser door, and find the thin flourescent green, or bright red color nylon cord located in the front left or right areas of the dispenser area, this will allow you to manually release the door lock. Empty the washer, close the door and perform another drain and spin cycle, if the door lock still fails, you may need to have the door lock assy replaced, especially if the door lock is making a click, or buzzing soung like it wants to operate, if it's completely quiet than you may need the board replaced...Pleazer Appliance...
Aug 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Samsung vrt fl code
Check both parts of the latch mechanism. Something may have gotten stuck or the latching device may have broken
Sep 08, 2012 | Samsung WF337AA Front Load Washer
When the load starts, the washer buzzes and then the FL code is shown
This is a Failed to Lock Code. Check the seal at the lock to see if something is in the way or blocking it. Overloading or having too many clothes in the way will also cause the door to fail to seat correctly. Generally however the lock mechanism needs to be replaced or reseated as it is no longer making contact with the control board.
Jan 22, 2012 | Maytag Neptune MAH5500B Front Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washer buzzes and shows the fl and do on display when we try to start it this was after the door was opened during the cycle
It appears that the door latch safety interlock was damaged or broken when the door was opened mid-cycle.
The codes "fl" Failure and "do" Door Open, seem to indicate that the latch and/or door switch need to be replaced. I tried to find a drawing and parts list for your washer, based on the model you selected, but could not locate one. If you can get the full model number, you can check for the replacement part at searspartsdirect.com or call them to get the part number.
If you look inside the door of the washer, you can see if the catch (on the moveable door) or the latch, on the washer cabinet) is the broken or damaged.
The repair is relatively straightforward and easy to do, with simple hand tools. Just make sure to disconnect the washer power cord before doing any work on it. Once you've done that, open the door and remove the screws and you should be able to remove either or both, the catch and the latch switch and reinstall the new ones, once you have them.
That should resolve the problem you're having.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Maytag Neptune MAH7500WH Front Load Washer
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
91 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
