Question about Brother XL-3500
Buttonholes w/ brother xl 3022
When making buttonholes my machine will do the 1'st bar and go up the left side, when it comes down the right side it will make a bar in the middle and then go on to the bottom. What am I doing wrong ? I have the proper foot.
I drop down and lightly push the buttonhole lever . WHEN do you let go of it ?
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
rizla
  • 1463 Answers
SOURCE: I need instrutions on how
hi hrkids
will anything thing here be of help XL-2600/2600i/2610:
riz.
Posted on Apr 21, 2008
  • 16 Answers
SOURCE: Brother Super Galaxie 2100 Buttonhole lever not working
I have a problem with my CS 8150 which sometimes tells me to lower the pressure foot even though I had already did it. What clears the problem for me is that I eject the thread cassette and re-install and I can go ahead and sew. Try that to see if it will quit telling you to pull down the lever.
Posted on Sep 15, 2008
SOURCE: how do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Posted on Oct 14, 2008
RickE1
  • 202 Answers
SOURCE: I am trying to use the buttonhole 3A foot. I
Hi, its very common for these to need to be recalibrated by a technician.
Possibly its time to have your machine serviced anyway as this is usually when they get recalibrated. I don't think you could be using it incorrectly as there really is just one way.
Rick
Posted on Oct 30, 2009
I don't know how to change needle postion when changing the foot to another one my machine is a brother xl 3022
Here's a manual for your machine:
Brother XL 3010 Operation Manual
It appears that your machine does not have the ability for the user to change the needle position. Instead, it seems that the selection of the specific stitch pattern determines where the needle is positioned, ie #1 appears to set the needle in the left position but other stitch and width selection will move the needle position.
Oct 16, 2017 | Brother Sewing Machines
How do I drop the feed dogs on my Brother sewing machine?
Altho I don't have your model, most of the Brother sewing machines have a slider kind of button on the back of the machine right in back of the needle assembly. So you push it to one side and voil? ! the feed dogs are dropped down. Don't forget to put them back up when you need them again :-)
Oct 14, 2014 | Brother Sewing Machines
How to use the buttonhole attachment
You haven't listed the model of your machine so its hard to give you step by step instructions as there is variations in how buttonholes are done. Some machines have a 4 step sequence on a knob, it may be colour coded with a little buttonhole symbol.
Other computerised machines you just select the buttonhole style and pull down a lever behind the needle bar which lines up with the special buttonhole foot to trigger the return stitching down the buttonhole side.
Have a look in your accessories and see if you have a buttonhole foot like this
tally_girl_76.jpg If so, remove the current pressure foot and put this on, clip it onto the little metal bar you see near the front of the foot. Now put your button into the back ratchet bit of the foot, you pull it out, place the button in there and close it up firmly to hold the button in place. This helps to give you the right length buttonhole.
Now you need to start the buttonhole stitching sequence and sorry, but I don't know what your machine's is, you really need to check the manual for this bit. It may be a 1,2,3,4 sequence on a dial and probably stitch length set to 0.5 so its a closed up satin stitch.
But you stitch the butttonhole in the folowing sequence:
near bar tack, reverse down right hand long side, far bar tack, then back up left hand long side, then a couple of stitches in place to finish off.
The buttonhole foot will sit firmly on your fabric and the inner part of it will move backwards as the machine stitches, then comes back to the front again.
The computerised machines will have a little lever you pull down and these will trigger on a lug on the buttonhole foot to start the reverse stitching at the right length buttonhole. Sometimes they will stitch both long sides in the same direction too, so sequence is near bar tack, down right hand side, far bartack, then it will stitch back to front in little straight stitches, then do the left hand long side to the back and finish off.
On early machines, you actually set the stitch length to 0.5, and stitch width to 2 for sides and 4 for bartacks and made the buttonhole yourself by stitching down one long side, leaving the needle in the fabric and pivoting the work around, then stitching the bartack, then the other long side, then final bartack all manually. It can be done but obviously the new programmed ones are far easier and give consistently similar buttonholes on a garment.
ALWAYS, interface the fabric to be buttonholed, you'll never get a good practice buttonhole without interfacing in a sandwich between two layers of fabric so no point practicing without it.
And, never cut your buttonhole with the seam ripper unless you pin across the two ends first to make sure you don't have a woopsy moment and rip through the end bartack. I use a buttonhole knife and block of wood to cut and it ensures you never have a cutting disaster.
I also pull the thread tails through to the underside with a needle afterwards, tie them off and add a dab of fray stopper to make sure the buttonhole never unravels, then trim the ends off close.
I hope this helps you but obviously getting the manual to your machine would be a big help too.
Sep 21, 2011 | Husqvarna Sewing Machines
Lost my users manual- how do i clean and oil my brother xl-3022 sewing machine?
The brother website has free operation manuals
On the home page,, on the left hand side down towards
The bottom look for PRODUCT MANUALS
Click on it & it will take you to another page where you can
Pick your model number & download the manual
Jan 23, 2011 | Brother LS-1217 Mechanical Sewing Machine
I need to learn how to make a buttonhole on my Husqvarna 210 electronic sewing machine.My manual is gone.
You may be able to still get that manual, check with your dealer. If not you can call Viking at: 1-800-474-6437 if it's out of print for a photo copy of the original owners manual.
To make a buttonhole do the following:
1. Turn the selector dial to the top position, That is the first step of the buttonhole.
2. Turn the stitch length dial (the bottom dial) to the picture of the buttonhole, it's between the 0 and the 1 on the dial.
3 Put on the "C" foot and put the tension dial, (the small dial just above and to the right of the needle) on 4.
4. On a test fabric, sew about an inch or so and stop. Turn the selector dial down one click and sew the bar tack of the buttonhole. Just do a few passes, don't build up alot of stitches here.
5. Turn the dial down another click to the 3rd step, the right side of the buttonhole and sew until you reach the place where you started the left column of the buttonhole and stop.
6. Turn the dial UPWARD one click to the bar tack position again and do another bar tack like you did at the top of the buttonhole. Don't build up alot of stitches here, about three passes does the trick.
7 Remove the fabric from the machine and when you cut the threads, leave a tail about 2 inches or so of the thread. From the back side of the buttonhole, pull gently on the thread and a loop from the front thread will appear on the backside. Pull the front thread to the rear and tie off the threads and then cut them close to the knot you tied and the buttonhole will not come apart.
Oct 14, 2009 | Husqvarna Viking 1
Need instructions on button holes
Move the width bar to between 4 and 6, the higher number makes a wider buttonhole. Move the length bar to the middle or right of the buttonhole icon. Set the selector dial on #1, snap on the buttonhole foot with a button snugged up in the back slot. Pull down the button stop lever behind the needle threader and make sure it is lower than the edge of the buttonhole foot, and behind the little tab on the left side of the buttonhole foot. Position the needle over where you want the bottom of the buttonhole to be. It will bartack, sew backwards, bar tack and sew forward based on the size of your button. When it is finished it will stop sewing. Turn the stitch selector dial to #2 to reset, then back to #1 to sew the next buttonhole. Practice on scraps until you are happy with the stitch length and width.
Apr 07, 2009 | New Home MX-3123 Computerized Sewing...
Uneven buttonhole sides
Hi, I'm a Bernina tech and can tell you you need to have a technician recalibrate your buttonhole foot to the machine. There is a function in the service program to do this. Also the machine will need a speed calibration once the buttonhole foot is calibrated. This will definatly solve the problem.
May 23, 2008 | Bernina Virtuosa 160
Brother XL-3500 Logo
377 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
