Question about Samsung Dishwashers
Code symbol: lights on Heavy and Delicate blinking during the cleaning cycle. By the codes it says it is a heater error. How should I check this or fix this? Thank you
3 Suggested Answers
bbtoast
  • 319 Answers
SOURCE: Bosch SHU9915uc/u12 making noise
TJ
I have a possible answer to your diagnostic test, see below, if this doesn't help, let me know, and I will provide more help!
Brian
SHU 991x/992x (Integra) MODELS
To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, SCRUB WASH, REGULAR WASH and RINSE & HOLD), press and hold each program button. When SCRUB WASH program button is pressed, CLEAN light also comes on andan audible tone (?beep?) also occurs.
To start testing, press both POWER SCRUB PLUS and REGULAR WASH buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
SCRUB WASH = Water filling fault (over or under filling)
REGULAR WASH = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), SCRUB WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), REGULAR WASH light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Posted on Jan 19, 2008
  • 188 Answers
SOURCE: clean light blinking will not start
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 06, 2009
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
Dishwasher stops when starting to fill
Your dishwasher is equipped with a leakage sensor located at the bottom center of the unit underneath. If any water is detected, the sensor shuts down power until the problem is corrected. Check underneath FIRST to make SURE there is no water dribbling from a small leak. Look for telltale residue trails left from evaporated water on the hoses, lines, motors, etc.
You can enter diagnostic mode by pressing and holding for 2 seconds the POWER, HEAVY, AND DELICATE BUTTONS. All the l.e.d. s will be lit for 2 seconds, then the software version will be displayed in binary code by the blinking of the WASH, DRY, CLEAN, AND CHILD LOCK l.e.d. s. Next, and this will take some practice, if there are error codes present(sets of blinking lights) you will have to read them to be able to find out where the problem(s) is.
•Press the Heavy + Delicate + Power buttons at the same time for two seconds to enter Service Test Mode.
•All LEDs are displayed for the first two seconds and then Software version will be indicated in Binary Code using LEDS ....Wash / Dry / Clean/Child Lock
•Just like the DMR series you advance through the test next mode by pressing the Normal button . However each test will run by itself (see sequence chart on next page) when test has completed an led will light to indicate test is done and you can then advance to the next test .
•Code list and descriptions located on pp#3. Note: Like the DMR series the codes are displayed during operation or test modes and are not stored in memory.
Service Test Modes & Codes
I hope the following pix are clear enough for you to read, if not I will re-send them! I hope this helps you!
Jul 16, 2015 | Samsung DMT300RFS Builtin Dishwasher
I'm working on a kenmore 11046472501   Washer
Did you get an error code? Also, take a wet-dry vac and **** the drain line. Sometimes there will be a blockage there as well. Have you checked the door switch for continuity?
Nov 03, 2012 | Washing Machines
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Jan 27, 2012 | Samsung DMT300RFW Builtin Dishwasher
Clean light blinks
clean light blinks is a form of error codes. The most common is a heater circuit error, 7 times then a pause is the heater. to clear the code press the heated dry then normal in a key dance 4 times. this starts a diagnostic cycle, takes several min to complete. let it run. it will work until it sees the fault again. this code is caused when the main control does not read a water temp increase 3 times in a row. If this continues call for service.
Jan 08, 2012 | Maytag Dishwashers
Dishwashers Logo
1,140 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
