Question about Universal Battery Exit Sign Red Led Backup White Housing
The lights don't go on when you push the test light button
  • 3 Answers
Have you checked the wires to the power source, also is the battery good?
Posted on Sep 29, 2010
My windshield wipers wont work when i push the buttons
Check the fuse. Should tell you on the fuse cover which one is for the wipers, or in your manual, if you have one. Or, you can use a test light to check all the fuses. Just ground the test light and turn the ignition key to the on position. Touch the test light to each side of the fuse ( the silver part that shows through the fuse). If it lights up when you touch each side, its good. If only one side, the fuse is no good.
Mar 03, 2013 | 1995 Isuzu Rodeo
Why don't the lights flash when pushing the lock button on remote
not all vehicles do but if your vehicle is supposed to check your battery in remote or check fuse box in vehicle for flashers.
Dec 25, 2012 | 1999 Plymouth Grand Voyager
I just purchased a 2006 Navigator and the button to lower the rear seats, does not work. I don't have manual yet, and don't know how to check the fuses, or if this is even the problem...
locate the fuse box under driver side instrument panel,use a test light hook clip to ground and probe each side of each fuse test light should light when you touch or probe top both side of fuse test light should light.if one side dont light fuse blowed both sides light fuse good.also use test light see if power at the switch if yes problem in the seat motor lower mechanism.
Sep 01, 2012 | 2006 Lincoln Navigator
How to reset check oil light
You mean the change oil light, right ??
If it has a red button on the fuse box, you turn the key on and push the button, the change oil light should flash, then you push the red button until the light goes off.
If you don't have the red button, you turn the key on, push the gas pedal to the floor three or four times, and the light should go off.
The method for your model should be in the back of your owners manual.
Aug 19, 2012 | 2002 Pontiac Grand Am
Brake lights & Hazzard lights don't work; fuse ok... High mounted center brake light works... Turn signals work...suspect problem is multifunction lever Power drain to battery constant...2...
As for the brake lights push brake pedal down while pushing on and wiggling the hazard switch.If the brake lights come on then replace the multi-function switch.
Aug 10, 2011 | 1997 Oldsmobile Bravada
My horn on my 1992 mazda B2600 does not work
If you have a test light, unplug the single wire that's plugged into the horn. Connect your test light clip to a good ground such as the engine block or even the battery. Then insert the point of the test light into the terminal of the wire that you unhooked from the horn.Have someone push the horn button and if the test light lights, you do have power to the horn. If it doesn't light, you might check the horn relay. Sorry, I can't tell you where it is in your Mazda though. If the test light did light up when the horn button was pushed, then I would suspect that it isn't grounded properly, or, the horn is defective. Try unbolting the horn and sanding off the rust that formed between the horn and where it mounts. Typically, horns are mounted to the vehicle's frame.
Jul 12, 2011 | 1992 Mazda B-Series
My signal is good on my labtop,but i cannot connect,there is a lock ,how to removed it
The lock means that your wireless network is secured with a password. If the router is yours, and you don't remember what the password is, you can reset the router with the reset button on the back end of the router. This button is very small, needing a pin to push it. It's located right next to the antenna, and has a small arrow pointing at it.
While holding the button down, watch for the light on the front labeled "test" to light. This should take 5-10 seconds. Don't release the button until the light comes on. Once it does, let go of the button and wait for the router to reboot.
May 08, 2011 | NetGear WGT624 Wireless Router
Two led water purity monitor problem
The LED monitor should light up as Green when the membrane is producing the proper water quality (80%+ TDS rejection). If the LED light stays Red this indicates the RO membrane is bad, all the filters (including membrane) should be changed and system sanitized. The batteries in the TDS monitor should be changed yearly also. Don't have a lot of faith in that indicator light. The best way to test for TDS rejection is with a digital TDS meter which indicates the amount of rejection. Compare the incoming water to the product water of the RO.
RJ
Jul 17, 2009 | Culligan Under Sink Water Filter
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Blinking lights on Front Panel
I've finally tracked down the manual and it the fault code is as follows
"Indicates a fault in the heater or in the thermistor"
You can go into a fault tracing mode by pushing the "Rinse Hold" button five times within 15 seconds. The first, third, fifth and seventh lights will flash when in this mode and you can test the following parts by pressing the corresponding button. I'm going to try the heater test below and assume that if that works the fault must be with the Thermistor. The other tests could be useful for other faults.
User manual found here
Rinse Hold - tests detergent solenoid, detergent flaps open after about 60sec
Pots & Pans - tests Rinse Aid Solenoid, rinse aid will flow down door
Normal Wash - tests water inlet valve, water can be heard entering
Light Wash - tests ventilator solenoid, there will be a click followed by a rattling noise
Quick Wash - tests the heater, the element heats up, WARNING don’t touch element HOT
Temp - tests circulation pump, the pump starts
Dry - test outlet pump, the pump starts
Manual says to push 55 and 65 degree button to exit, I have no idea where those are so will probably just switch off at wall to reset.
Hope this helps someone. I rang ASKO and they said they didn’t know what the fault code meant so either they can’t read or their service sucks, probably a bit of both!
Feb 12, 2009 | Asko D1716 Built-in Dishwasher
Universal Battery Exit Sign Red Led  Backup White Housing Logo
113 people viewed this question
Top Universal Battery Electrical Supplies Experts
Steve
Gene Haynes
Are you an Universal Battery Electrical Supply Expert? Answer questions, earn points and help others
