Question about Creative Labs Zen Digital Media Player
Device is hanged in rebuilding - Creative Labs Zen Digital Media Player
  • 64 Answers
Turn it off completely. Press the reset button using a paper-clip. Then afterwards, flash again the firmware.
Posted on Sep 29, 2010
When i switch on my Creative labs zen it show the rebuilding,now what to do.....
Posted on Sep 16, 2011
Prosub atmosair rebuild manual I have an older prosub that I got a rebuild kit for but need instructions to take it apart and rebuild it.
You need to consult with a factory technician. Your life depends on these devices. I am certified in USD Survivair and no one can set those after a rebuild kit without special tools and measuring devices.
Jul 26, 2015 | Scuba Diving & Snorkeling
New brakes installed, left front wheel squeaking loudly.... Worse than before
Did you replace the rotors when you did the brakes? Old rotors will have a ridge the the new pads will ride on and squeal. Second, it is possible that the caliper is hanging up. That will make your new pads ride the rotor all the time and squeal like crazy. You can either rebuild the caliper, or replace with new. I replace with new myself because the old caliper is probably pitted inside and making it hang up. Good luck.
Feb 28, 2012 | 2004 Nissan XTerra
The gas lines popped off on my fj 1100 there is a group of lines (about 4-5) tied together and two other ones just hanging around that just popped right off and leaking gas. where do they belong?
If you mean they are hanging below the carbs, these are carb overflow and breathers.
This would then mean your carbs are flooding and need a clean, and may also mean the fuel tap requires a rebuild, its a vacumn opperated tap, this means the fuel should not flow until the engine is running
Aug 12, 2011 | 1984 Yamaha FJ 1100
Why are the brakes on my 1986 S10 Chevy hanging up?
The Brake calipers are sticking. You can get a rebuild kit or just replace them.
Nov 03, 2010 | 1984 Chevrolet S-10
Troybilt weedwacker won't stay running. It starts
you may need to rebuild the carburetor.Check all the gas lines for cracks or leaks.Check the primer bulb if it has one.Then try and readjust the carburetor.If that still don't work,then try to rebuild the carburetor.
Sep 02, 2009 | Garden
Zen won't charge and continually rebuilds library unsuccessfully
buy a new battery, or try cleaning the connections dist is a big problem at small devices like this...you your vacume cleaner, but BE CAREFUL!!!
Aug 25, 2009 | Creative Labs ZEN V Plus MP3 Player
98 grand prix gtp tranny
The tranny is called a 4T65E-HD(heavy duty). The rebuild kits are the same for both supercharged and non-supercharged cars. The occasional harshness is caused by the EPC solenoid hanging up from wear. I recommend installing a Superior Shift Correction kit, 4th clutch hub (the splines strip), EPC, and TCC/PWM solenoid.
This combo works great!
Apr 03, 2009 | 1998 Pontiac Grand Prix
Sansa dioesn't recognize audiobooks
Maybe the new firmware will fix this.
"OGG placed in Audiobook or podcast folder shows up in Music directory." (see below)
(http://www.anythingbutipod.com/forum/showthread.php?t=30954)
01.01.30
Enhancements:
  • FLAC decoder support
  • Allow Podcasts to skip episodes using FF / REW
  • New startup and shutoff images
  • Improved the time to rebuild the metadata
  • Improved M3U playlist support
  • Enhancements for sorting Podcast contents which do not have their track number ID3 tag information
  • Separate missing license error message for Audible and generic Audiobooks. Message changed to instruct the customer in how to resolve the problem
Bugs Fixed:
  • OGG placed in Audiobook or podcast folder shows up in Music directory
  • Delete song from a long playlist causes the device to hang
  • Selecting “Back to Music List” while playing FM/Voice recordings will display double “Play All” on screen & will cause device to hang upon selecting “Play All”
  • Certain tag information for mp3 files will cause the device to hang or freeze
  • Made OGG file Tags not case sensitive
  • Noise problem on voice recording
  • Device in MTP mode will jump back to AutoSelect mode after UI format
  • Device behaves erratically when file extension got changed (i.e. .txt to .mp3, .jpg to .wma)
  • All Audiobooks should show 1/1 if Chapter Mode is OFF
  • Certain Rhapsody tracks show clicking noises
  • Deactivation message “Synchronize to listen to your Audiobooks” for Audible is uninformative and irrelevant
Oct 07, 2008 | SanDisk Sansa Clip MP3 Player
Handheld is hanged
Sounds like you need to do a hard reset, Take the battery out fo the phone while the device is on.
This will rebuild your apps, and should fix the corruption.
Other wise you might have to reload your apps or your os on the device.
Mar 04, 2008 | RIM BlackBerry 8700g Smartphone
Re-Building Library
Perhaps try reloading the firmware? The following link gives the info.. http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=true&docid=F0F4980C22BCD325E030030ABD622DEF&journalid=2E66FA153D5411DC8D9EFF8AAB8AFD42&l=en&s=dhs#3
Jul 28, 2007 | Dell Pocket DJ MP3 Player
Creative Labs Zen Digital Media Player Logo
262 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
