Question about Fuji FinePix S5200 / S5600 Digital Camera
Focus error the camera shows a focus error on the screen
  • 9 more comments
  • amylynn81 Jun 13, 2008
    Just bought this camera, was shipped to me. as soon as i put the battery in, it said, "focus error" I tried everything. what can i do?
  • jwilson3401 Aug 25, 2008
    My camera was working fine and when I went to turn it back on, a got a focus error prompt. I have tried pushing every button and new batteries. Any suggustions?
  • spoonbill200 Sep 19, 2008
    just turned the thing on and I got the focus error. tried new batt. no help
  • Anonymous Oct 04, 2008
    can this be fixed or do i need a new camera?
  • Anonymous Oct 13, 2008
    same thing for me, was working fine and then focus error...
  • junni Oct 28, 2008
    when i turn my camama on witch is (finepix S5200 fuji digital camera) it say on the screen "foucus error" and it has a "blur" on the back ground halp wat can i do?? do i need a new camara cuse thats NOT COOL if we should be able to fix it!!!!!!! my email is junnibug@hotmail.com or shemeykeunnice@hotmail.com HELP PLZ.
  • wilsonsignsa Dec 01, 2008
    s5200 "focus error" . nothing "happened" to the camera ! now it's a paperweight ! $ 300.00 camera year and a half old! fuji will fix for $155.00 !! found others on-line that will fix for $125 + . also have a useless a120 fuji ($80 +) just stopped working all together. other posts are true- fuji sucks! GO CANNON OR NIKON !!
  • mbange123 Dec 23, 2008
    Same Problem.
  • Mininet Jan 06, 2009
    When I turn the camera on, it comes up with "Focus error". It just happened radomly, but from the previous posts, I see this is a problem with this camera. :(
  • Laura0246 Mar 02, 2009
    I've read several posts suggesting taking my camera apart. Does anyone have pictures or diagrams with parts labled? I'm afraid I'll break or further damage my camera if I try to fix it without images for reference.
    Thanks
  • david Mar 03, 2009
    As long as you take it steady and have a box with compartments in for all the screws at different stages you should be all right.
    This model has the older style wires with different size plugs so you really can't go wrong. I think it is only the screen and possibly the keypad that have ribbon strips to worry about.
    There is very little in there really.
    2 circuit boards, lens unit and flash unit.
    borrow a camera and photograph each stage
  • 244 Answers
The zoom and focus operate on screw thread drives. 1 of these has detatched resulting in "ZOOM ERROR" and locked the camera up. Dis-assemble lens and re-attach drive.
Posted on Jan 25, 2009
  • david Jan 26, 2009
    Hi, Start by removing all the securing screws for the casing. There should be 2 on each side and 3 underneath. 2 of the one's underneath will be tri-wing screws (security screws) so you will need to purchase a screwdriver for this ( I paid £1 for mine on ebay). Make sure there are no screws located under the rubber cover for the usb and av sockets ( Im working from memory here)
    Best to have a box with compartments in to put screws etc in as you dis-assemble to aid re-assembly. Open battery compartment ( this helps lock the case together) and gentley open the case. It will have plastic clips holding it together also so be carefull of these. The lcd is screwed to the back case too and conected to the pcb as is the key pad so don't lift the back away instantly incase the ribbons tear. Once you have the back removed its just a case of unscrewing the pcb and unplugging the different cables. I think the power board is under the main pcb so will have to remove this to get at the lens unit( Beware of electric shock. It does hurt!) Remove the fixing screws for the lens unit and remove it from the case. The zoom is on a long screw thread which runs from a small motor and gear drive. There should be a little plastic or metal attachment that runs up and down the thread which should be located on the sliding lens which is the zoom. If I remember the motor assembly needs to be removed to re-attach the zoom assembly to the drive thread. Then re-assemble.
    If you get stuck email me daveward712@aol.com
    Problem Solver:
  • 12 Answers
This is the info I received from Fuijifilms about this error:
When a "!FOCUS ERROR" message is displayed on your FinePix digital
camera
, change or charge the batteries, then switch the camera off and
on again 2 or 3 times, being certain not to touch the lens. Removing the
batteries for approximately 30 minutes may also resolve this error.
If the problem persists, you may wish to send your camera directly to us
for a technical evaluation. Please send it (preferably via FedEx or UPS
for tracking purposes) to the following address:
FUJIFILM U.S.A., Inc.
1100 King George Post Road
Edison, NJ 08837
Attn: Camera Repair Department
Please include a copy or the original sales receipt and/or
proof-of-purchase along with a note including your name, address, and
daytime phone number.
Upon receipt, a Camera Repair Agent will evaluate your camera and
contact you under separate cover. For information regarding warranty,
estimate or turn-around time, please contact our Camera Repair
Department by dialing 1-800-659-3854, option #1, then option #1 again.
Posted on Jan 09, 2009
  • Mininet Jan 26, 2009
    daveward712 Can you give me an idea where to start? I don't want to start removing screws willy-nilly and then be stuck with pieces parts. :) I'm assuming I would start with the screws at the back of the camera?
  • Mininet Mar 08, 2009
    I took my camera apart like Dave suggested. It's really not that hard to keep track of things. It's like a puzzle, everything can only go back into it's own spot. I used another digital camera and took pictures along the way just in case, but didn't need them. Unfortunately, I discovered that there is actually a piece broken so the lense won't move. It's not connected to the threaded bar anymore. :(
    Good luck.
Please help me!
Posted on Oct 09, 2008
Panasonic LUMIX DMC-FH4 is showing system eror focus. How solve it ?
Can you tell exactly what is on the screen please. The system error focus is not supposed to be an real error that is displayed on your camera.
"System error" is possible. But if switching of and a few moments later switching on does not change the error on the dis[lay, you should contact a Panasonic certified repair centre.
May 24, 2014 | Panasonic Lumix DMC-FH4 Digital Camera -...
Focus Error
It's a message given when the internal lenses get jammed, possibly due to debris within the gears that move the focus. The "Focus Error" message can involve many FujiFilm models.
Nov 19, 2009 | Fuji FinePix Z100fd Digital Camera
Lens Error
well don't play with ur lens on ur own give it to the ppl they will repair ur lens and give them a phtocopy of ur warranty card.
But yes if the problem persists thats is the test they do after repair they might cahe ur camera .....But there are slime chances for an exchange
Jan 05, 2009 | Nikon COOLPIX L18 Digital Camera
Focus error appear on screen
i just help the zoom to get out with a thin screwdriver and now the "ZOOM ERROR" message disappear, but i have another problem. The camera does not show the target (what to shoot) on the screen. It shows ONLY pictures on card.
I tried everything, but the target i choose does not appear on the screen.
Dec 09, 2008 | Cameras
Camara not focusing/ zoom not working
Its an error code and shows problem of Lens mechanism.
Lens focus / zoom motor is stuck that's why camera gives out of focus image.
You need to replace Lens Assembly and it would cost you more then camera worth.
Oct 26, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Out of focus
Focus motor in lens assembly of camera is jammed and needs to replaced, you can get complete lens assembly from Sony if you wish to repair it at your own. Error code 61-10 shows focus problem in lens mechanism.
Sep 01, 2008 | Sony DSC-T7 Digital Camera
Focus error show up and can't take any pictures
Had "FOCUS ERROR" appear on my Finepix S9500. The lens seemed to be stuck at the extremity of focus range. I resorted to hitting the camera on a table while turning it off (because this is when it sounded as though the focus motor was trying to move the lens back). Guess what? It worked!!!!!
Aug 11, 2008 | Cameras
Sony dcr trv14e picture blurred on camcorder screen with error 16.00
Error code 61:00 shows focus system problem in lens mechanism. If u can open camera, check focus lens drive motor, it can be jamed.
Jun 08, 2008 | Cameras
Fuji FinePix S5200 / S5600 Digital Camera Logo
1,126 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
