Question about Kenmore Washing Machines
Kenmore Washer Model #110-25842400 Type 111 Serial #CR4074815 The water will not shut off. I assume a timer or something needs to be replaced but I can't find this model anywhere online. Can you help? My email address is annamcope@gmail.com
  • 213 Answers
SOURCE: Kenmore 70 series Model: 22702 100 Series CL2738136 Type 111 will not hold water
the drain pipe in the wall needs to be as tall as the cabnet of the washer. if it is the see how much hose is going into the drain pipe. should only be about 9 to 12 inches into the pipe. any more than that will cause a syphon and suck the water out as it fills
Posted on Nov 27, 2007
jsrock516
  • 5911 Answers
SOURCE: kenmore washer won't drain
The symptoms you describe are often caused by a lid switch malfunction. It may be loose or not making good contact. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. A replacement switch usually cost between $25 and $35. I hope this helps you. Let me know if you require further assistance.
Posted on Aug 17, 2008
jyackle5
  • 8197 Answers
SOURCE: 1. I need a manual
Here is the manual.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0401315.pdf
Posted on Dec 17, 2008
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
SOURCE: how old is my washer
to determine your model year. Sorry for the delay!! You have to look at the letter that is the third-to-last character on the model number. The original website had this formatted in bold red, which a very stupid blogger girl who shall remain clueless (sigh?me) had omitted. On our own model number, the second-to-last letter is a T Example model numbers: LRS6233BW1= 1994 SF367PEYW1= 1992 LE6685XPW1= 1985 ET22PKXXW0= 1991 EV150CXKW0 = 1982 K = 1982 or 2001 L = 1983 or 2002 M = 1984 or 2003 P = 1985 or 2004 R = 1986 or 2005 S = 1987 or 2006 T = 1988 or 2007 V = 1989 or 2008 W = 1990 or 2009 X = 1991 or 2010 Y = 1992 or 2011 A = 1993 or 2012 B = 1994 or 2013 D = 1995 or 2014 E = 1996 or 2015 F = 1997 or 2016 G = 1998 or 2017 H = 1999 or 2018 J = 2000 or 2019 so urs shud be 2002...... thank you.... i dont remember any washing machine lasting for 26 years so definitely not 1983
Posted on Jun 09, 2009
I would like to know the year of my Kenmore special edition washer and dyer SM 97 10804-4
Hi C,
Looks like around 2001 according to Serial #.
110 prefix means Whirlpool manufactured this item for kenmore
Dec 29, 2014 | Kenmore Washing Machines
Fills with water and then nothing kenmore washer model 23822100 type 111
Top load machines will fill with water while the lid is open. Your problem starts when you close your lid. NOTHING happens. I believe this to be your LID SWITCH . Replace or have replaced and you should be OK. GOOD LUCK.
Jul 26, 2011 | Kenmore 23822 Top Load Washer
How do you take the motor out of a kenmore washer: Model #\r\n20702-990/ serial #CK2842388/ type 111.
u will need a service manual to help u in this matter (appliancerepairplanet.vstore.ca
Dec 07, 2010 | Kenmore Washing Machines
Kenmore washing machine Type 111 Model 110 - 26492503 water over flowing while starting the cycle. Not stopping on the level of water required.
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won't be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won't tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you'll need to replace the water inlet valve. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 07, 2010 | Kenmore 24032\24036 Top Load Washer
My top loader Kenmore type 111 is working fine until it get to the spin cycle. It won't spin and it makes a really loud buzzing sound. like a weedwacker or something. Help!!!
verify that hot and cold water are not reversed and BOTH are turned on. Sounds like water is shut off. Water valves are noisy without water pressure.
Sep 06, 2010 | Kenmore 22642 Top Load Washer
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 22, 2009 | Kenmore Washing Machines
Tyler,
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer stopped in first rinse cycle
do you hear a clicking noise when you close the lid if not check your lid switch
Dec 30, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
99 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
