Question about Microsoft Xbox 360 Console
I have a full red ring. It won't do anything. Is it dead or can I fix it somehow? Is there a reset button? My son tried playing a blu Ray disc and the full red ring appeared
  • 4,102 Answers
Hi you have got the dreaded red ring of death, this is very common with all xboxes and their are people out their that will fix them for you for a fee.
their is nothing you can do yourself to solve this problem as its a case of taking the xbox apart and removing the heat sinks and the x clamps and fitting new parts and new heat sink paste, this is a big job and requires special tools. so its not for the novice to do.
i do the repairs to these on a regular basis and 8 out of 10 i fix work again but others tend to be to far gone.
any way the reason you are getting this warning light is due to it over heating, check the date on the sticker on the back of the xbox as it is covered by warranty for 3 years for this exact fault so if its less than 3 years old go to the xbox website and get them to replace it for you, if its outside this time then you have 2 options you could either repair it or sell it.
you can buy repair kits and get the instructions off the net but without having done it before it can by really hard to do and you could do more harm than good.
when they built these they used cheap parts and cheap heat sink paste now over time this causes it to over heat and then you get the dreaded red ring of death and this shows you the either the gpu or cpu chip has over heated.
now the repair involves taking the xbox apart which is not easy but can be done you need to then remove the x clamps and then remove both heat sinks. once their removed you need to clean them up and remove all the old heat sink paste and use new paste, you also need to get xbox rrod repair kit as you wont be using the cheap x clamp bits anymore these will go in the bin as this is what caused the problem in the first place.
let me know what you would like to do or if you need further assistance ok
i also be damaged xbox's but im based in UK
if you are going to do this yourself then make sure you have no warranty left as this fault is covered for 3 years by microsoft so if the date on the sticker on the back of the xbox is within this time all you need to do is go to the microsoft webiste and tell them and they will give you a replacement.
i charge 25pound to do the repair so you should be looking around this price if you are paying someone also their is no guarantee the repair will work as the damage caused by the over heating could have destroyed the cpu or gpu chip but you wont know this till after the repair work has been done.
if you are doing the work yourself then you need to get a erpair guide off the net so just google rrod repair guide and this will list loads of sties with these guides, you will also need to buy an xbox 360 rrod repair kit, you can get these off ebay for next to nothing, then you need to get some heat sink paste and some special torque screwdrivers to remove the xbox case.
this is not an easy job to do and getting it wrong can do a lot more harm than good if you put to much pressure on the heat sinks when you put them back on this will destroy the gpu and cpu chip so be warned.
make sure you get a guide and correct tools or if you are unsure get someone to do it who knows what their doing.
plz rate this solution as i have a whole page of unrated posts, thanks
x1,
Posted on Sep 29, 2010
How do I unlock the region coding on my HK BDS680 to play discs from all regions?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Region code settings to many popular DVDs and Blu-ray players are given.
Nov 17, 2015 | Televison & Video
Why wont my samsung dvd-vr357 play blu ray disks
Educated guess is you need a blu ray player. I have several very expensive Pioneer Elite DVD players and they cannot play blu ray. Blu ray is a multi level glorified DVD which you need at least a blu ray player to play in almost all cases.
You can play dvds on a blue ray but not the reverse in most cases. If you play a dvd on a blu ray player it kicks the video up to HD for the DVD.
Apr 14, 2014 | Televison & Video
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Sharp Blu-rAy player won't play Blu-ray discs but
Due to the nature of players often if the optical Pickup unit inside is dirty or failing Blu-rays will not play but DVD's will.
May 06, 2012 | Sharp Televison & Video
We have a Panasonic Blu Ray player that for some reason won't play the blu ray discs only regular discs now???
It sounds like the bluray laser is worn out. Try cleaning the lens with a Blu-ray lens cleaner. If that dosen't help it might be the blu-ray laser it self. The laser is dead. If you are under warranty the call the manufacture for service. Shop around for current retail prices. Bluray players have gone down alot and it might be better to go ahead a buy a new player.
May 24, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Can not play blu-ray on my bdp-s300
If the issue is with only new discs, then you can install the Firmware update.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5861&mdl=BDPS300
If the issue is with all the discs, then try resetting the Player from the Menu. If the issue still persists, try power resetting the player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the issue still persists, then the player requires service.
Jul 26, 2010 | Sony BDP-S300 Blu-Ray Disc Player
PS3 WON'T PLAY BLU-RAY DISCS
The problem is all in the settings. You probably have a 1080i television that cannot display in 1080p. To fix this go to the main menu and go to:
Settings:
Video Settings
Then Blu Ray Disc and make it turn the Display BD in 1080p 24hz or whatever. Once you do that, start the Blu Ray Disc again, and you should be able to watch it. This all happened because your tv doesn't display 1080p.
Hope this helps!
Jan 19, 2009 | Sony Playstation 3 (PS3) Console
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
