Question about Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire Sumbersible Well Pump R5sub82
Our water pressure stopped overnite, we hit the reset button and heard the clicking in the box but no pumping or pressure increase, after several tries the water pressure suddenly kicked up and worked, has for three days, now, after a washing of clothes no pressure -same problem but this time no kick in of pressure pump, the power box is clicking on and off to no avail Ideas?
  • 990 Answers
The clicking you hear inside the little box is the contacts that send power to the pump. They have probably gotten corroded to the point they would not make contact. By kicking on and off you probably loosened some carbon, it was still making a poor connection and carboned up again. Only this time causing the points to stick open (so no clicking) You can take this switch apart and give it a good cleaning then reset the points. Or you can get a new switch and install it on the system. Ether way be sure that the power is off for these operations as this is all the power going to the pump.
Posted on Sep 29, 2010
Pressure switch clicks off and on will not stop
could be several things that cause this. I would first try increasing the spread between the upper and lower limits. it they are set too close together you can get this kind of bouncing on and off. Also, how old is the switch? as they age they get less and less accurate at reading the pressure accurately and this could be the problem. Longer shot, could be a leak in the well check valve. Water leaking back down into the well and that keeps turning the pump back on when there are no faucets open.
Jan 08, 2016 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Lose press on retrn to pool using Hayward S166t with brand new veri flow pump attached. I back wash and pressure restored is excellent but within 15 or twenty min drops off again.
what is the water like?
Dirty? Green? Murky? Cloudy?
Something is clogging the filter!
Let me ask this, you said: "Pressure drops Off" ???
Do you have a pressure guage on the filter?
Does the pressure increase? Or does it Decrease?
This will be an important piece of information!!!!
  • If pressure increases on the pressure gauge...
    • then filter is working and filtering out dirt and filter is clogging up.
  • If pressure decreases on the filters pressure gauge,
    • then the basket, or literally anything that is decreasing or stopping the water from getting to the pump, or more precisely to the internal impeller of the pump!
Most commonly - plugged impeller, baskets need to be checked, enough water in pool? etc.
May 17, 2015 | Hayward Pool & Spa
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Electric pressure washer will not start
CLEAN FRESH WATER IS IMPORTANT FOR THESE PUMPS, I ALWAYS USE A HIT OF ARMOR ALL IN THE PUMP AFTER USE . YOU MIGHT SEE IF IT'S GETTING POWER TO THE MOTOR MIGHT HAVE A BAD GFIC ? PLUG IT IN PICK UP THE UNIT AND TRY DROPPING IT FROM A FOOT OFF THE GROUND, THIS JAR MIGHT SHOCK IT BACK TO LIFE ?
. Jay the pool pump whisperer FLORIDA 32750
Sep 21, 2012 | Karcher K5.540 2,000 PSI 1.4 GPM Electric...
My jacuzzie starts and stops wen it is runing i have a fl code
FL is a flow error, you may not have enough water going over filter housing. Jets are they open?
is your heater fitted with a pressure switch? when on FL locate pressure switch wheel and turn all the way anti clockwise until it stops then slowly wind back until you hear a click reset in control box - you have reset pressure switch.
If you have done this and still show FL or heater is not fitted with pressure switch then your LOW speed on pump maybe faulty (new pump) or heater maybe scaled up with lime scale and reducing water flow through heater - remove scale from heater, flush through and increase ANTI-SCALE
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 07, 2010 | Jacuzzi Pool & Spa
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
I own a 3.86 model and have used it two times. I
was you using the machine on a electic extension & was it full unwoven.
chance thermal overload in switch knocked out.
there is also a little micro switch on the bypass valve that might be stucking , just in clip and test.
Jul 02, 2009 | Northstar Professional Series Pressure...
Sudden increase in water pressure
Replaced the pressure switch and water pressure returned to normal.
Jun 16, 2009 | Plumbing
Jacuzzi Brothers 1/2 Hp 8gpm 2 Wire Sumbersible Well Pump R5sub82 Logo
196 people viewed this question
Top Jacuzzi Garden Experts
john h
Jay Finke
Jay Finke
Ian Kime
Ian Kime
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
